VBA Code - Message Box
Busymanjohn
Hi guys, looking for some help, I have a file which contains some VBA code that shows a Message Box when a number does not appear in a list, I would like to have a Message box appear when the number does appear in the list ,, so basically have a two boxes, one to say, "Does not appear" and another that says "Yes it appears" ,,,, or words to that effect.
It would help if you could show the code you have. Guessing at the layout...
[pre]
If Range("A2") <> 2 Then
MsgBox "Does not appear"
MsgBox "Yes it appears"
[/pre]
