I have a code to lock 2 columns completely using vba. However, this locks all other columns. I would like a user to be able to edit and update the other columns and rows with data (the unlocked ones). The problem is that this can only be done by unlocking the cells manually. Is there a vba code that can be run to unlock the cells that need to be populated manually, instead of doing this each time on numerous sheets.
