Raghava@rock
Hi Team,
I need help to get VBA code to Check if the Value in Cell A5 is not less than -10 and Greater than 10 then the Value in A5 should be copied and pasted in column E.
if A5 Value is -6 it should not paste any value in column E
if A5 Value is 16 it should paste the value in column E
thank you
Raghava Sharma
thank you
Raghava Sharma
