VBA code copying formula down a column jumping predetermined rows
Inun
Please help with VBA excel code .I have formula in excel sheet in cell F6 want to copy same formula down that same F column after every 14th row the last formula will be inserted in in cell F2533 .Thanks for your help in advance .
▬▬▬▬▬▬▬▬▬ Mod edit : thread moved to appropriate forum !
Stevie
Hi Inun,
I have written some code to do this, but it seems starting at 6 and going every 14 rows (6,20,34...etc) ends at 2526
or going every 13 rows (6,19,32...etc) ends at 2528.
Please clarify what you want as 2533-6 is not a multiple of 14.
Either way, here is the code if you wish to modify it for your use.
Sub copyFormula()
    Application.Calculation = xlManual
    Dim ws As Worksheet
    Set ws = Sheets("Sheet1")
    Dim form1 As String
    Dim row As Double
    form1 = ws.Range("F6").formula
    For row = 6 To 2533 Step 13
        ws.Cells(row, 6).Formula = form1
    Application.Calculation = xlAutomatic
If this was helpful, please click 'Like'!
p45cal
If, in Stevie's code, you replace both instances of .formula with .formular1c1 the F6 formula's absolute/relative references will be respected.
Inun
Hi Inun,
Sub copyFormula()
    Dim ws As Worksheet
    Dim form1 As String
    Dim row As Double
If this was helpful, please click 'Like'![/quote
Hi Inun,
Sub copyFormula()
    Dim ws As Worksheet
    Dim form1 As String
    Dim row As Double
Hi Stevie
Sorry late response the steps is indeed 13 but the last cell where the formula needs to be inserted is 2533
I pasted the code and am getting run time error 9 saying subscript out of range
Thanks for a quick response
The other thing my sheet is sheet38 but the tab called FCW .Do I need to write FWC or sheet38 in in this -Set ws = Sheets("Sheet1")
Inun
Hi
Thanks for your response
I have tried that getting the same error message
How do I get round this ?
Stevie
Hi Inun,
I still don't understand which cells need the formula and I would imagine the error is to do with something about your sheet which I don't know about.
Please upload your workbook as per the forum suggested best practice.
Stevie
Marc L
Without a complete explanation of the need neither an attachment
(as per forum rules), just activate the Macro recorder and operate
manually at least for a couple of destination cells then post here
your generated code using the appropriate code icon …
Inun
will try manual and if this do not works I may send the attachment ( sensitive info will see if this will be allowed )
Thanks Marc
Inun
Hi Inun,
Stevie
The formula is in F6 and that needs going into F20 , F34 up to F2533
Thanks Stevie
Marc L
No sensitive data in any attachment !
Better is you just first operate manually.
As if it can't work manually so it can't neither work by code …
p45cal
Sub copyFormula()
    Dim ws As Worksheet
    Set ws = ActiveSheet 'Sheets("Sheet1") 'this change means it works on whichever sheet is the active sheet.
    Dim form1 As String
    Dim row As Long
    form1 = ws.Range("F6").Formula
    For row = 6 To 2533 Step 14
    'add the last formula (because the last cell with formula added will be on row 2526):
    ws.Cells(2533, 6).Formula = form1
Inun
Sub copyFormula()
    Dim ws As Worksheet
    Dim form1 As String
    Dim row As Long
P45 cal
This is running the code and looks magic but strange enough the code is not putting the right answers to F20 , F34 etc don't know why this is a very good starting point and much appreciated thanks
Stevie
Hi Inun,
collating your responses and making some guesses, I am going to assume that cell F2533 doesn't actually contain the formula, it's just the end of the range you are specifying.
Also, adding P45cal's R1C1 suggestion, try this:
Sub copyFormula()
   Dim ws As Worksheet
   Set ws = Sheets("FCW")
   Dim form1 AsString
   Dim row AsDouble
   form1 = ws.Range("F6").formulaR1C1
        ws.Cells(row, 6).FormulaR1C1 = form1
If this helped, please click 'Like'!
Stevie
P45 cal
This is likely due to not using R1C1 as P45cal previously suggested. try my response above.
Inun
Hi Inun,
Sub copyFormula()
    Dim ws As Worksheet
    Dim form1 As String
    Dim row As Double
This is the formula in F6 that needs copied into F20 , F33 up to F2533
p45Cal's code worked but it is keeping that * A7 pinned down to A7 instead of moving down to A21 ,A35 up to A2534 thanks
=SUM(SUMIFS('Subcontractors Lia OnsiteMcA'!Q:Q,'Subcontractors Lia OnsiteMcA'!S:S,'FWC - Programme'!C:C,'Subcontractors Lia OnsiteMcA'!D:D,'FWC - Programme'!A:A),IF(SUMIFS('Raw Data'!O:O,'Raw Data'!AQ:AQ,"External construction")>SUMIFS('Subcontractors Lia OnsiteMcA'!Q:Q,'Subcontractors Lia OnsiteMcA'!S:S,'FWC - Programme'!C:C),(SUMIFS('Raw Data'!O:O,'Raw Data'!AQ:AQ,"External construction")-SUMIFS('Subcontractors Lia OnsiteMcA'!Q:Q,'Subcontractors Lia OnsiteMcA'!S:S,'FWC - Programme'!C:C))*A7,0),(SUMIF('Subcontractors Lia OnsiteMcA'!D:D,"Various",'Subcontractors Lia OnsiteMcA'!Q:Q)*A7))
Inun
Hi Inun,
Sub copyFormula()
   Dim ws As Worksheet
   Dim form1 AsString
   Dim row AsDouble
F2533 actually contain the last formula
your code is bringing error and P45cal's is running the code and working but giving a difference in the totals I had before and this is what I am investigating thanks
Inun
yes the absolute and relative referencing was the issue with the numbers
I suspect I may have more spaces or less between where the formulas need to go so after every 14 may not be constant to get round this can we modify the code to insert the formula where the row is in the line with where it says "direct works" down the column -again the last cell where the formula will go is F2533 thanks
Inun
Sub copyFormula()
    Dim ws As Worksheet
    Dim form1 As String
    Dim row As Long
p45cal has done the magic that is brilliant the formula worked perfectly I had more space on 2 cases that is the reason why my total was different initially
many thanks
Inun
I want to say thank you to Stevie , p45cal , Marc L and all members in this forum who have taken time to read and respond to this request
That was a quick turnaround and it has made my life easier
p45cal
Q1. In which column might we find "direct works"?
Q2. Is "direct works" the only thing in the cell?
Inun
Hi
direct works is in C6 and it is the only thing in the cell
thanks
the other thing I appear to face all the time I run any code the excel spreadsheets are crashing and freezing and not responding .This has happened with other codes i have used in the past and is happening now again with the code you have just helped me with .What could be causing this ?
p45cal
Hi
I'll come up with something later…
With a formula like:
where there are many references to entire columns (red highlighting), this means that for each column 1 million+ cells are being evaluated, which takes time. Try to reduce them to the likes of $A$1:$A$1000, and $AQ$1:$AQ$1000, where you change the 1000 to the maximum number of rows ever likely to exist on the corresponding sheets (but bear in mind that all ranges referred to within a SUMIFS function should be the same size).
Inun
Ok will narrow the range then and make sure columns same size in SUMIFS thanks
