Malleshg24
Hi Team,
I am using below code and its giving Correct result.
Situation1
Column A, B, C, are my Raw data,
Situation1, Column F,G,H Are my filter Criteria List.{Filter In}
Situation2, Same situation but exclude Column J Criteria list (Filter Out)
Situation2 - Column J,K,L Are my filter Criteria List.
How to achieve same result via advanced filter in both Situation.
Criteria list my Increase.
if possible can you Suggest a dynamic function to cover Multiple Situations Like this. (10-15 Situation)
mg
Situation1
Sub Count_as_Per_Criteria()
Dim ar1 As Variant
Dim ar2 As Variant
Dim ar3 As Variant
ar1 = Sheet1.Range("F3", Range("F" & Rows.Count).End(xlUp))
ar2 = Sheet1.Range("G3", Range("G" & Rows.Count).End(xlUp))
ar3 = Sheet1.Range("H3", Range("H" & Rows.Count).End(xlUp))
Dim i As Long, Situation1 As Long, lr As Long
lr = Sheet1.Range("A" & Rows.Count).End(xlUp).Row
'Situaction 1 Include all Criteria ' Code is working
For i = 2 To lr
If IsNumeric(Application.Match(Sheet1.Cells(i, 1).Value, ar1, 0)) Then
If IsNumeric(Application.Match(Sheet1.Cells(i, 2).Value, ar2, 0)) Then
If IsNumeric(Application.Match(Sheet1.Cells(i, 3).Value, ar3, 0)) Then
Sheet1.Cells(i, 1).Resize(1, 3).Font.Color = vbBlue
Situation1 = Situation1 + 1
MsgBox Situation1
'----------Situation2 Count--------------------
ar1 = Sheet1.Range("J3", Range("J" & Rows.Count).End(xlUp))
ar2 = Sheet1.Range("K3", Range("K" & Rows.Count).End(xlUp))
ar3 = Sheet1.Range("L3", Range("L" & Rows.Count).End(xlUp))
Dim Situation2 As Long
For i = 2 To lr
If IsNumeric(Application.Match(Sheet1.Cells(i, 1).Value, ar1, 0)) = False Then 'Something wrong here, How to exclude.
Sheet1.Cells(i, 1).Resize(1, 3).Font.Color = vbRed
Situation2 = Situation2 + 1
MsgBox Situation2
mg
