V3 how to split data into columns between underscore and and dash when there can be more than one
karynd
back in sept 22 Bosco_yip you gave me an amazing formula and it worked a treat until the year changed to 2023
this was the amazing formulas but it is now producing the information and putting the date as 2023 and the very last one combining the date and name
=IFERROR(FILTERXML("<a><b>"&SUBSTITUTE(SUBSTITUTE($A1,"2022 - ","___"),"___","</b><b>")&"</b></a>","//b["&(COLUMN(A$1)+INT((COLUMN(A$1)-1)/2)+1)&"]"),"")
this is what the formula is providing now that we have changed to the year 2023 yet the 1st date should read 22/11/22 and the 6th date should be 13 jan 2023 but the name should then split into a 6th name
if there is not a date of 2023 the 6th date and name splits but the dates all say 2023 when they should say 2022 if they are the year of 2022
I am hoping Bosco you will know what I need to do to fix - I have tried playing with the formula but I cant get it to correct.
I am sure it is a simple fix but my brain just get my head around it
thanks heaps
cheers Karyn
1st date1st name 2nd date2nd name 3rd date3rd name4th date4th name5th date5th name6th date
22/11/2023​
Elise Pretto
22/11/2023​
Julie Clancy
1/12/2023​
Julie Clancy
8/12/2023​
Julie Clancy
23/12/2023​
Julie Clancy13 Jan 2023 - Julie Clancy
AUSP Policy ID: 360279 Eff: 18/08/2022 Manya Wittingslow
___22 Nov 2022 - Elise Pretto___
Followed up broker - Dean Bowen is dealing with this now.
___22 Nov 2022 - Julie Clancy___
Spoke to Dean he has requested accounts details from CBN.
___01 Dec 2022 - Julie Clancy___
Corrections are being processed by the broker and the remaining amount will be taken back soon - unallocated listed undert the name of Boneo Maze.
___08 Dec 2022 - Julie Clancy___
Still on unallocated.
___23 Dec 2022 - Julie Clancy___
Checked again the broker hasn't finalised this yet - sent a follow up.
___13 Jan 2023 - Julie Clancy___
You give us only one (1) source data and 11 formula results as per above.
In order avoid to any misunderstanding.
Please write down "What is your expected result?" for us to work.
In the attached is your sample data in msg#1 above in cell A8.
In cell B8 is the formula:
=DROP(TEXTSPLIT(SUBSTITUTE(TEXTJOIN(" - ",TRUE,CHOOSECOLS(TEXTSPLIT(A8,"___"&CHAR(10),CHAR(10)&"___"),1)),"___","")," - "),,1)
The formula in cell B4 is similar but includes the Policy ID in the first cell.
I hope you have a version of Excel which is sufficiently up to date.
I haven't figured out why the results of the original formula in cell B1 have all dates in 2023.
Link to previous thread: https://chandoo.org/forum/threads/h...d-and-dash-when-there-can-be-more-than.49141/
  • Chandoo50736SplitData(B1).xlsx
thanks Bosco for having a look at this again
the previous thread where you designed this formula
so your formula broke up the info in the source splitting the date and name between the dash and underscore of the source
of course the data could at any time have more than 6 names and dates so be able to copy across and pick up as many as are in the source and there could be a mix of years in the data like this data showed with dates of 2022 and 2023
the expected result would be similar that the formula is currently supplying except pull in the correct dates of 2022 and the last column split out the date of 2023 and name in a separate column - so below is the expected result
is that the info you require?
thanks heaps :)
1st date1st name 2nd date2nd name 3rd date3rd name4th date4th name5th date5th name6th date6th name
22/11/2022​
Elise Pretto
22/11/2022​
Julie Clancy
1/12/2022​
Julie Clancy
8/12/2022​
Julie Clancy
23/12/2022​
Julie Clancy
13/01/2023​
Julie Clancy
thankyou so much for your response :) - i have confirmed my excel is the most upto date. that other formula did not work . the formula that Bosco has supplied had worked a treat until we had a mix of 2022 and 2023 dates
cheers
Try,
In B2, revised formula (with highlighted red) copied across right:
=IFERROR(FILTERXML("<a><b>"&SUBSTITUTE(SUBSTITUTE(SUBSTITUTE($A2,"2022 - ","2022___"),"2023 - ","2023___"),"___","</b><b>")&"</b></a>","//b["&COLUMN(A$1)+INT((COLUMN(A$1)-1)/2)+1&"]"),"")
82553
  • Split data between underscore.xlsx
Try,
Bosco_Yip to the rescue again - you are a superstar and exactly what I needed thank you so much :)
