Sub Test()
Dim http As New XMLHTTP60
Dim ihttp As New XMLHTTP60
Dim html As New HTMLDocument
Dim ihtml As New HTMLDocument
Dim post As Object
Dim tdElem As Object
Dim s As Variant
Dim v As Variant
Dim myUrl As String
Dim strUrl As String
Dim postData As String
Dim dt As Date
Dim lDay As Integer
Dim lMnth As Integer
Dim lYear As Integer
Dim r As Long
dt = #2/12/2018#
lDay = Day(dt): lMnth = Month(dt): lYear = Year(dt)
myUrl = "http://www.handelsregisterbekanntmachungen.de/?aktion=suche"
postData = "suchart=uneingeschr&button=Suche+starten&land=&gericht=&gericht_name=&seite=&l=&r=&all=false&vt=" & lDay & "&vm=" & lMnth & "&vj=" & lYear & "&bt=" & lDay & "&bm=" & lMnth & "&bj=" & lYear & "&fname=&fsitz=&rubrik=&az=&gegenstand=1&anzv=10&order=1"
With http
.Open "POST", myUrl, False
.setRequestHeader "Content-Type", "application/x-www-form-urlencoded"
.send postData
html.body.innerHTML = .responseText
If InStr(html.body.innerHTML, "Es wurden 0 Treffer gefunden.") > 0 Then MsgBox "No Results Found", vbExclamation: Exit Sub
For Each post In html.getElementsByTagName("li")
With post.getElementsByTagName("a")
If .Length And InStr(.Item(0).href, "javascript") Then
strUrl = "http://www.handelsregisterbekanntmachungen.de/skripte/hrb.php?" & Replace(Replace(Split(.Item(0).href, "(")(1), ")", ""), "'", "")
With ihttp
.Open "GET", strUrl, False
.send
ihtml.body.innerHTML = .responseText
r = r + 1
For Each tdElem In ihtml.getElementsByTagName("td")
If InStr(tdElem.innerText, "Aktenzeichen") > 0 Then
Cells(r, 1).Value = Trim(Split(tdElem.innerText, "Aktenzeichen")(0))
Cells(r, 3).Value = Trim(Replace(Split(tdElem.innerText, "Aktenzeichen")(1), ":", ""))
ElseIf InStr(tdElem.innerText, "Bekannt gemacht am:") > 0 Then
Cells(r, 2).Value = Trim(Mid(tdElem.innerText, 20))
ElseIf InStr(tdElem.innerText, Cells(r, 3).Value) > 0 Then
Cells(r, 4).Value = MyUDF(tdElem.innerText, CStr(Cells(r, 3).Value & ":"), ",")
Cells(r, 6).Value = GetPostCode(tdElem.innerText)
Cells(r, 7).Value = Replace(MyUDF(tdElem.innerText, CStr(Cells(r, 6).Value), "."), ")", "")
Cells(r, 5).Value = MyUDF(tdElem.innerText, CStr(Cells(r, 4).Value), CStr(Cells(r, 6).Value))
Cells(r, 5).Value = Application.Trim(Replace(Replace(Replace(Cells(r, 5).Value, Cells(r, 7).Value, ""), "(", ""), ",", ""))
If InStr(tdElem.innerText, "Vorstand: ") > 0 Then
s = MyUDF(tdElem.innerText, "Vorstand: ", ";")
Cells(r, 8).Value = Trim(Split(s, ",")(0) & "," & Split(s, ",")(1))
ElseIf InStr(tdElem.innerText, "Gesellschafter: ") > 0 Then
Cells(r, 8).Value = MyUDF(tdElem.innerText, "Gesellschafter: ", ",")
v = Split(tdElem.innerText, ". ")
s = Split(v(UBound(v)), ": ")(1)
Cells(r, 8).Value = Split(s, ",")(0) & "," & Split(s, ",")(1)
Next tdElem
Next post
Function MyUDF(s As String, b As String, a As String) As String
Dim arr() As String
Dim r As String
arr = Split(s, b)
If UBound(arr) > 0 Then
r = arr(1)
arr = Split(r, a)
If UBound(arr) > 0 Then r = arr(0)
MyUDF = Trim(r)
End Function
Function GetPostCode(strAdd As String)
Dim regex As Object
Dim allM As Object
Dim result As String
Set regex = CreateObject("VBScript.Regexp")
With regex
.Pattern = "(\s\d{5}\s)"
.Global = True
.IgnoreCase = True
Set allM = regex.Execute(strAdd)
If allM.Count <> 0 Then result = allM.Item(0).SubMatches.Item(0)
GetPostCode = result
End Function
