YasserKhalil
Hello everyone
I am still trying to learn more about scraping and I could devise a code that enables me to get the desired results
Here's the code
But as a matter of trying to learn more about xmlhttp I am seeking for a way to get the same results but without using ie .. so I think using xmlhttp will be more efficient specially I could see post data after setting up the desired choices for the search process ..
Thanks advanced for help
Here's the code
Sub Test()
Dim e As Variant
Dim ie As Object
Dim ulElem As Object
Dim liElem As Object
Dim anchElem As Object
Dim dt As Date
Dim lDay As Integer
Dim lMnth As Integer
Dim lYear As Integer
Dim r As Long
Set ie = CreateObject("InternetExplorer.Application")
dt = Date - 2
lDay = Day(dt)
lMnth = Month(dt)
lYear = Year(dt)
With ie
.Visible = False
.navigate ("http://www.handelsregisterbekanntmachungen.de/?aktion=suche#Ergebnis")
Do: DoEvents: Loop Until .readyState = 4
For Each e In ie.document.getElementsByTagName("select")
If Len(e.innerText) = 56 Then
e.selectedIndex = lDay
ElseIf Len(e.innerText) = 18 Then
e.selectedIndex = lMnth
ElseIf Left(e.innerText, 8) = "----2000" Then
e.selectedIndex = lYear - 1999
ElseIf InStr(e.innerText, "Alle Bekanntmachungen") > 0 Then
e.selectedIndex = 1
Next e
For Each e In ie.document.getElementsByTagName("input")
If e.Value = "Suche starten" Then e.Click: Exit For
Next e
Application.Wait Now() + TimeValue("00:00:05")
If InStr(ie.document.body.innerHTML, "Es wurden 0 Treffer gefunden.") > 0 Then
MsgBox "No Results Found", vbExclamation: Exit Sub
For Each ulElem In ie.document.getElementsByTagName("b")
For Each liElem In ulElem.getElementsByTagName("li")
Set anchElem = liElem.getElementsByTagName("a")
If anchElem.Length > 0 Then
r = r + 1
Cells(r, 1) = Mid(anchElem.Item(0).innerText, 11)
Next liElem
Next ulElem
