Using CountA and Offset formulas for 13 month dynamic graphs
Nikki
Hi!
All the examples show that the data is in rows, but if the data is in columns, how does one get this to work?
I have tried the below but it doesn't work
Data in one row along columns
=OFFSET(Sheet1!$J$8,COUNTA(Sheet1!$J$8:$AG$8)*0,0,1,13)
This works well because the data is in one column but along rows
=OFFSET('Cheat Sheet '!$A$26,COUNT('Cheat Sheet '!$A$26:$A$49)-1,0,-13,1)
Nikki
Firstly Welcome to the Chandoo.org Forums
The format of Offset is: =Offset(Ref, Rows, Columns, [Height], [Width])
So in your first example
The Rows are offset from J8 by COUNTA(Sheet1!$J$8:$AG$8)*0 Rows
Which should be 0 (I assume there is a mistake in the typing)
The Columns are offset 0
The size is 1 Row high and 13 Columns wide
So in the second example
It probably should be something like
=OFFSET('Cheat Sheet '!$A$26,0,COUNT('Cheat Sheet '!$A$26:$A$49)-1,1,13)
Read more about Offset here: http://chandoo.org/wp/2008/11/19/vlookup-match-and-offset-explained-in-plain-english-spreadcheats/
Here's a little help:
There's an extension out there called Name Manager. (http://www.jkp-ads.com/officemarketplacenm-en.asp). Amongst other things, it has an evaluate button which really helps troubleshoot wonky dynamic ranges.
Thanks Hui and for your help but I just can't get the formala to work. "On paper" it all looks fine but the formula doesn't seem to recognise the Offset function. The * was not a typing error - EXCEL returns an error without it?
Our Dashboards have data from Jan 2010 to Dec 2011 going accross in columns, so i want the graphs to read the latest 13 months' data.
[the second formula works perfectly but then the data is going down in rows which is not how our Dashboards are set up]
Hi Nikki ,
Can you post the exact formula you are using , along with the cell in which you are using this formula ?
Nikki
Can you post the file or some data ?
Also make sure your using Dates as Numbers not as Text
Headcount January 2010 February 2010 March 2010 April 2010 May 2010
Perms 52 53 54 55
Temps 2 3 4 5
Thanks All - wasn't able to paste all the data, but the range is from I8:AG10. I would like the graphs to reflect the latest 13 months of data.The COUNTA formula doesn't seem to work?
Hi Nikki ,
Create the following two dynamic named ranges :
1. Date_Range , referring to : =OFFSET(Sheet2!$J$8,0,COUNTA(Sheet2!$J$8:$AG$8)-13,1,13)
2. Data_Range1 , referring to : =OFFSET(Sheet2!$J$9,0,COUNTA(Sheet2!$J$9:$AG$9)-13,1,13)
Now , you can plot your chart to reflect the most recent 13 months of data.
Add more data ranges , using similar formulae , to plot any additional series.
