Using complex Array
Manish Bhatia
=IF(ISERROR(INDEX(EOD.xlsx!$A$1:$I$1648,SMALL(IF(AND(EOD.xlsx!$I$1:$I$1648>=40000,EOD.xlsx!$I$1:$I$1648<50000),ROW(EOD.xlsx!$I$1:$I$1648)),ROW(1:1)),1)),"",INDEX(EOD.xlsx!$A$1:$I$1648,SMALL(IF(AND(EOD.xlsx!$I$1:$I$1648>=40000,EOD.xlsx!$I$1:$I$1648<50000),ROW(EOD.xlsx!$I$1:$I$1648)),ROW(1:1)),1)).....Need help with this formula. If I use the above formula to check only one condition(>40000), it gives the desired result BUT with AND operator to check two logical values, the result is not coming... can anyone help please? Thanks in advance
Hi Manish ,
The way to use multiple conditions in an array IF statement is to nest them , not use the AND function ; try this array entered formula , using CTRL SHIFT ENTER :
=IF(ISERROR(INDEX(EOD.xlsx!$A$1:$I$1648,SMALL(IF(EOD.xlsx!$I$1:$I$1648>=40000,IF(EOD.xlsx!$I$1:$I$1648<50000,ROW(EOD.xlsx!$I$1:$I$1648))),ROW(1:1)),1)),"",INDEX(EOD.xlsx!$A$1:$I$1648,SMALL(IF(EOD.xlsx!$I$1:$I$1648>=40000,IF(EOD.xlsx!$I$1:$I$1648<50000,ROW(EOD.xlsx!$I$1:$I$1648))),ROW(1:1)),1))
Hi Narayan,
Thanks for your reply. Yah, you are right about nested IF. I figured out and changed my formula and also had to change a reference cell. It worked. But I really appreciate your reply.
Now after finishing this, I moved onto adding something more to my sheet. Hey BTW, these sheets are only my personal sheets & not for any professional project or assignment.
Now let's say that the result of the above formula is "Manish", displayed in sheet 1 in column A1. And "Manish" is also there somewhere in Column A(A1:A1650) with more data in Sheet 2.
I want to click on "Manish" in Sheet 1 & it should send me to "Manish" in Sheet 2. So basically am trying to use hyperlink with Vlookup. It gives me error"Cannot Find the Specified File". I am not writing the Link location & making a silly mistake, I guess. Not successful yet. Any Suggestions?
here it is
=HYPERLINK(VLOOKUP(IF(ISERROR(INDEX(EOD.xlsx!$A$1:$I$1650,SMALL(IF(EOD.xlsx!$I$1:$I$1650>3000000,ROW(EOD.xlsx!$A$1:$A$1650)),ROW(1:1)),1)),"",INDEX(EOD.xlsx!$A$1:$I$1650,SMALL(IF(EOD.xlsx!$I$1:$I$1650>3000000,ROW(EOD.xlsx!$A$1:$A$1650)),ROW(1:1)),1)),EOD.xlsx!A1:A1650,1,FALSE))
Hi Manish ,
Try this array formula , entered using CTRL SHIFT ENTER :
=HYPERLINK(IF(ISERROR(INDEX(Sheet3!$A$1:$I$1650,SMALL(IF(Sheet3!$I$1:$I$1650>3000000,ROW(Sheet3!$A$1:$A$1650)),ROW(1:1)),1)),"","#Sheet3!" & ADDRESS(SMALL(IF(Sheet3!$I$1:$I$1650>3000000,ROW(Sheet3!$A$1:$A$1650)),ROW(1:1)),COLUMN(Sheet3!$A$1))),INDEX(Sheet3!$A$1:$I$1650,SMALL(IF(Sheet3!$I$1:$I$1650>3000000,ROW(Sheet3!$A$1:$A$1650)),ROW(1:1)),1))
