Using an automated method to validate Finance reports against ERP reports
Gunasekaran
Dear Sir,
I am working on a VBA project, so I am wondering if it is possible to validate both Report Grant Total Values automatically. As a new member of this team, I need your help. I would appreciate your advice.
Steps are mentioned in that attachment File Data.
In the Finance Report, I must enter the Sub Total values based on ERP Report MEP Codes. If there is no MEP code available in the Finance Report. "NA" needs to be updated
Is it possible to do this validation in macro????
BobBridges
Your instructions inside the workbook read:
1) I have to validate manually for Each MEP Code Grand Total Value vs Finance Report
2) In Original Finance Report, Rows are dynamic, but last Row before Row should be like "INCOME_EXPENSE - Net Income or (Loss)"
3) I have Enter Trial Balance Sum Total Values and Validation Formula in Finance Report to get the Result
4) Based on ERP Report MEP Code wise, I have to entered that Sub Total values in Finance Report. If no MEP Code avaiable in Finance Report. Update "NA"
Is it Possible this Validation in Macro ????
I think you mean that you have two numbers, on two separate worksheets, that you want to compare to be sure they're equal. But what numbers? I think you should tell us explicitly how the two numbers are calculated.
(Yes, a macro can probably do it. You just haven't told us how you do it manually.)
Gunasekaran
Hi Sir, I mentioned Detailed my Simple Task PRocess Steps in this attachment. Kindly let me know if any question.
A quick note on my challenge, how to memorize each MEP code, and then finds it in the finance report in one by one,
Expecting - Validate by MEP Code Total Vs. INCOME_EXPENSE - Net Income or (Loss) in Finance Report
BobBridges
The new instructions are better, but there are parts I still don't understand. The first step is to copy 'ERP Report'!K:L to a new worksheet for processing; I get that. The second step finds data in a pivot table—but I never use pivot tables and don't know much about them. (Really I know almost nothing about them.) Where is that table?
We'll do this a step at a time.
Gunasekaran
Hi Sir,
I will handle the first two steps and then proceed to the pivot table. As a result of these row labels, the MEP code values will be updated in the Finance Report.
The MEP code can be found in Rows 8 of the Finance Report, followed by finding the MEP code. The last two rows after updating this MEP code value are in the same column.
In the Finance Report, Sir, you will find all the information you need
then Final Calculate by MEP Code Total Vs INCOME_EXPENSE - Net Income or (Loss) in Finance Report
80187
BobBridges
I'll paraphrase: Tell me if I understand this right:
1) Copy 'ERP Report'!K:L to a new worksheet.
2) Create a table in columns E and F. Each row contains one of the MEP codes in col E, and the sum of all the balances for that MEP code in col F.
Is that about right? If so, next question: I understood you to say that you were working on a VBA program to do this: How far have you gotten with it, so far? Can you show us what you've written? Then I can offer corrections.
Gunasekaran
Hi Sir, Thanks for your question and support, after multiple try and attempted, now I got that automatic solution via VBA... Thanks once again
vletm
Gunasekaran
Next code gives Your row 300 sums without Pivot-table to row 7 ( then no need to scroll so much ).
Was that ... what are You looking for?
Sub Do_It()
    FS = "Finance Report"
    ER = "ERP Report"
    With Sheets(ER)
        y = .UsedRange.Rows(.UsedRange.Rows.Count).Row
    With Sheets(FS)
        x = 3
        Do
            .Cells(7, x) = WorksheetFunction.SumIfs(Sheets(ER).Range("K1:K" & y), Sheets(ER).Range("L1:L" & y), .Cells(8, x))
            x = x + 1
        Loop Until .Cells(8, x) = Empty
        .Cells(7, "A").Activate
Gunasekaran
Hi Sir, this is my Hard code. may be little big code, if possible can u edit and give short term of code
>>> use code - tags <<<
ThisWorkbook.Worksheets("Temp").Delete
On Error GoTo 0
Sheets.Add(Before:=Sheets("BPC Master")).Name = "Temp"
Set Tem = ThisWorkbook.Worksheets("Temp")
ThisWorkbook.Worksheets("Segment TB workings").Select
ThisWorkbook.Worksheets("Segment TB workings").Range("K:L").Copy
Tem.Activate
Sheets("Temp").Range("A1").PasteSpecial Paste:=xlPasteValues, Operation:=xlNone, SkipBlanks _
        :=False, Transpose:=False
crr = "B1:B" & Cells(Rows.Count, "B").End(xlUp).Row
Range(crr) = Evaluate("IF(" & crr & "="""","""",TRIM(" & crr & "))")
lr = Tem.Range("E" & Rows.Count).End(xlUp).Row - 1
Set WR = ThisWorkbook.Sheets("BPC Master")
lrr = WR.Range("B" & Rows.Count).End(xlUp).Row
lgr = lrr - 5
For i = 2 To lr
Tem.Activate
loop_ctr = ActiveSheet.Range("E" & i).Value
loop_crr = ActiveSheet.Range("F" & i).Value
Set Rng = WR.Rows(8).Find(What:=loop_ctr)
   WR.Select
Rng.Select
MMG = WR.Range("B" & Rows.Count).End(xlUp).Row + 3
MMG = MMG - 8
Rng.Offset(MMG, 0).Value = loop_crr
Rng.Offset(MMG, 0).Offset(2, 0).Select
ActiveCell.FormulaR1C1 = "=R[-2]C+R[-6]C"
Range("B10000").End(xlUp).Offset(3, 0).Value = "TB Balance"
Range("B10000").End(xlUp).Interior.Color = 5296274
Range("B10000").End(xlUp).Offset(2, 0).Value = "TB Vs BPC Validation"
Gunasekaran
Hi Sir, Really Great Code,
But I would like to update this ERP Total Value for, after two rows of last row in Finance Report instead of 7th Rows.
Because then only I can put validation Formula . Both are possible in your code. kindly help me.
80199
Gunasekaran
i added Last row function, now its working.. thanks
>>> use code - tags <<<
Sub Do_It()
    ER = "ERP Report"
    With Sheets(ER)
    With Sheets(FS)
'     >>> mod
        lr = .Range("B" & Rows.Count).End(xlUp).Row + 2
'    <<< mod
        x = 3
        Do
            .Cells(lr, x) = WorksheetFunction.SumIfs(Sheets(ER).Range("K1:K" & y), Sheets(ER).Range("L1:L" & y), .Cells(8, x))
            x = x + 1
        .Cells(lr, "A").Activate
vletm
What formula?
What else?
Why those should be in the bottom? ... why not in the top?
You should able to give expected details at once ... many times so called 'minor changes' would mean a lot of extra work for others.
Gunasekaran
Really apologize for this. Now i need this validation formula attached in this excel file. in Finance Report sheet.
automatically while ERP report value updated time, this “Income_Expense - Net Income or (Less)” column + above row column value is added..
Gunasekaran
Hi Sir, thanks a lot for your quick support and help. It's Fine for me.. also really sorry for the inconvience for repeated questions...
