alberto.carrillom
I HAVE AN ISSUE WHEN I WANT TO DISPLAY MY FORM. THIS IS MY CODE OF THE STOCK LIST, IT APPEARS HIGHLIGHTED IN THE "frm.Show". ALSO I AM ATTACH THE CODE OF formStockDetailsNew. RUN TIME ERROR 6 OVERFLOW
>>> Please, do not shouting! ~ by using capital letters <<<
>>> Modify Your writing. <<<
>>> use code - tags <<<
>>> use code - tags <<<
Private Sub AddButtonn_Click()
Call AddRow
Private Sub AddRow()
Dim frm As New formStockDetailsNeww
frm.Show
Call AddDataToListBox
Private Sub NewButton_Click()
Call NewRow
Private Sub ButtonRemove_Click()
Call RemoveRow
Private Sub EditButton_Click()
Call EditRow
Private Sub DeleteButton_Click()
Call DeleteRow(listboxStock.ListIndex)
Private Sub ExitButton_Click()
Unload Me
Me.Width = 900
Me.Height = 500
Private Sub AddDataToListBox()
'Get the Range
Dim rg As Range
Set rg = GetRange()
'Link the data to the ListBox
With listboxStock
.RowSource = rg.Address(external:=True)
.ColumnCount = rg.Columns.Count
.ColumnWidths = "170;190;140;75;75;75"
.ColumnHeads = True
.ListIndex = 0
Private Sub EditRow()
' Check if an item is selected in the ListBox
If listboxStock.ListIndex >= 0 Then
Dim frm As New formStockDetailsEdit
frm.CurrentRow = listboxStock.ListIndex
frm.Show vbModal
MsgBox "Please select an item to edit.", vbExclamation
Private Sub RemoveRow()
Dim frm As New RemoveQtyForm
frm.Show vbModal
MsgBox "Please select an item to remove.", vbExclamation
Private Sub NewRow()
Dim frm As New AddQtyForm
frm.Show vbModal
Private m_currentRow As Long
Private Sub buttonClose_Click()
Unload Me
Private Sub buttonSave_Click()
If MsgBox("Do you wish to save this record?", vbYesNo, "Save record") = vbYes Then
'Write the data to the worksheet from controls
Call WriteDataToSheet
'Empty the textboxes
Call EmptyTextBoxes
'Create a new ID
Call CreateNewPartNumber
' HELPERS
Private Function WriteDataToSheet()
Dim NewRow As Long
With shStock
NewRow = .Cells(.Rows.Count, 1).End(xlUp).row + 1
.Cells(NewRow, 1).Value = textboxPartNumber.Value
.Cells(NewRow, 2).Value = textboxPartName.Value
.Cells(NewRow, 3).Value = textboxManufacturer.Value
.Cells(NewRow, 4).Value = textboxAddQuantity.Value
End Function
Public Sub EmptyTextBoxes()
Dim c As Control
For Each c In Me.Controls
If TypeName(c) = "TextBox" Then
c.Value = ""
Next c
'Create a new Part Number
'Initialize the controls
Call InitializeControls
Me.Width = 300
Me.Height = 280
Private Sub CreateNewPartNumber()
Me.textboxPartNumber.Value = GetNewPartNumber()
Public Sub InitializeControls()
Me.comboboxArea.List = GetAreas()
Me.comboboxArea.ListIndex = 0
