SUMIF INDIRECT with dynamic Sum Range
larsil
Hi, I am trying to change the Sum Range B:B dynamically, since the Sum Range on each worksheet (REGION) starts from column B to Z. So I am expecting when copying this formula across the columns the Sum Range B:B will change automatically to C:C and D:D etc. Using the initial formula, will not change the Sum Range of B:B. Please advise.
=SUMPRODUCT(SUMIF(INDIRECT("'"&REGIONS&"'!$A:$A"),$A12,INDIRECT("'"&REGIONS&"'!B:B")))
To:
=SUMPRODUCT(SUMIF(INDIRECT("'"&REGIONS&"'!$A:$A"),$A12,INDIRECT("'"&REGIONS&"'!C:C")))
=SUMPRODUCT(SUMIF(INDIRECT("'"&REGIONS&"'!$A:$A"),$A12,INDIRECT("'"&REGIONS&"'!D:D")))
Thanks,
L.A.
p45cal
Try in cell F12:
=SUMPRODUCT(SUMIF(INDIRECT("'"&REGIONS&"'!A:A"),$A12,OFFSET(INDIRECT("'"&REGIONS&"'!A:A"),0,COLUMN()-1)))
A formula that has no right whatsoever to work… but does.
Aside from that, I've used OFFSET which is a volatile function and tried INDEX instead but struggled.
bosco_yip
Another option for copy across formula while using INDIRECT function
In Sheet "Cash Forecast daily" , cell F12 change your formula :
From >>
=SUMPRODUCT(SUMIF(INDIRECT("'"&REGIONS&"'!$A:$A"),$A12,INDIRECT("'"&REGIONS&"'!F:F")))
To >>
=SUMPRODUCT(SUMIF(INDIRECT("'"&REGIONS&"'!$A:$A"),$A12,INDIRECT("'"&REGIONS&"'!R1C"&COLUMN(F1),0)))
Then, copied across right and down
Bosco
larsil
From >>
To >>
Bosco
This formula works too! thanks Bosco for your advice. I love this formula!!
