SUM BY USING "INDEX" AND "MATCH"
Muhammad
E3: =SUMPRODUCT(('Lookup table'!$D$5:$D$37)*('Lookup table'!$C$5:$C$37=C3))
Copy down
or
E3: =SUM(('Lookup table'!$C$5:$C$37=C3)*('Lookup table'!$D$5:$D$37)) Ctrl+Shift+Enter
Copy down
Match returns a single value being the position in the range of the value you are looking up
So you can't use match to return an array of values, which you require to do to add up multiple values
Why the question when there are other, simpler formulas that work?
hiii,
you can use below formula also
{=SUM(IF(C4='Lookup table'!$C$5:$C$37,'Lookup table'!$D$5:$D$37))}
ctrl+shift+enter
=SUMIF('Lookup table'!$C$5:$C$37,'output file'!C4,'Lookup table'!$D$5:$D$37)
rahul shewale
