Speed up Lookup Function?
TomNR
Hi all,
I currently have a lookup feature built but it takes 15-30 seconds to search through all 11500 rows of data.
I was wondering if there is a quicker method than the one I am using or if it is because of the size of the data it is searching through?
Thanks in advance!
Sub Lookup()
'declare variables
    Dim rngFind As Range
    Dim strFirstFind As String
    'error statement
    On Error GoTo errHandler:
    'clear the listbox
    lstLookup.Clear
    'look up parts or all of full name
    With Sheet7.Range("A:A")
        Set rngFind = .Find(txtLookup.Text, LookIn:=xlValues, lookat:=xlPart)
        'if value found then set a variable for the address
        If Not rngFind Is Nothing Then
            strFirstFind = rngFind.Address
            'add the values to the listbox
            Do
                If rngFind.Row > 1 Then
                    lstLookup.AddItem rngFind.Value
                    lstLookup.List(lstLookup.ListCount - 1, 1) = rngFind.Offset(0, 1)
                'find the next address to add
                Set rngFind = .FindNext(rngFind)
            Loop While Not rngFind Is Nothing And rngFind.Address <> strFirstFind
    'error block
    On Error GoTo 0
    Exit Sub
errHandler::
    MsgBox "An Error has Occurred  " & vbCrLf & "The error number is:  " _
          & Err.Number & vbCrLf & Err.Description & vbCrLf & _
          "Please notify the administrator"
Hi !
During execution, desactivate display via ScreenUpdating property …
I wish it was this easy, unfortunately it is not the ScreenUpdating that is the issue it is the amount of data it is searching through. (thank you for the suggestion though!)
I was wondering if there was a better method (i.e. VLookup) that would speed up this section of code?
Any help would be most appreciated!
          Do
I'd suggest an array:
  Dim vData
  Dim lLastRow  As Long
  Dim n  As Long
  Dim lCount  As Long
  Dim lCounter  As Long
  Dim sMatch  As String
  Dim asMatches()  As String
  sMatch = VBA.UCase$(txtLookup.Text)
  With Sheet7
  lLastRow = .Cells(.Rows.Count, "A").End(xlUp).Row
  lCount = Application.WorksheetFunction.CountIf(.Range("A1:A" & lLastRow), "*" & sMatch & "*")
  If lCount > 0 Then
  ReDim asMatches(1 To lCount, 1 To 2)
  lCounter = 1
  vData = .Range("A1:B" & lLastRow).Value2
  For n = 1 To UBound(vData, 1)
  If InStr(1, VBA.UCase$(vData(n, 1)), sMatch) <> 0 Then
  asMatches(lCounter, 1) = vData(n, 1)
  asMatches(lCounter, 2) = vData(n, 2)
  lCounter = lCounter + 1
  Next n
  lstLookup.List = asMatches
  lstLookup.Clear
  Dim vData
  Dim n  As Long
  Dim lCount  As Long
  With Sheet7
  If lCount > 0 Then
  lCounter = 1
  Next n
  lstLookup.Clear
Thanks for the reply Debaser!
It seems like your code doesn't break anything (no debug messages) but it doesn't populate the ListBox with the results of the Lookup value.
So I see it takes the sMatch from the txtLookup.text box on the Userform.
Then it search Sheet7, Column A for that value.
Once it finds it I do not understand how it is pulling the data found into the ListBox. I assume it is the asMatches but it is not working currently?
Once again thank you for the response!
Can you even post a small sample file so we can see what is going on ?
Are you looking up numbers, or text? The code would need a change if you are looking up number values.
pls share sample file which you are using now.
Of course, please find attached a sample file.
Basically if you click 'Add Project' it brings up a userform.
Then type in 1, 2 or 3. That brings up the results from the PivotTable in Sheet7.
Double click the result in the listbox, which populates the Userform. Then you type in your new value and click add to add it to a comparison table.
So this is all working fine and dandy but when you have 11500 rows of data in the pivot table it takes 20-30 seconds to search in the Userform which is not ideal.
Any suggestions on speeding this process up would be much appreciated!
  • Lookup Speed.xlsm
To look up numbers, try this:
Sub Lookup()
    Dim vData
    Dim n                     As Long
    Dim lCount                As Long
    lstLookup.Clear
    With Sheet7
        ReDim asMatches(1 To 2, 1 To lLastRow)
                asMatches(1, lCounter) = vData(n, 1)
                asMatches(2, lCounter) = vData(n, 2)
        Next n
        If lCounter > 0 Then
            ReDim Preserve asMatches(1 To 2, 1 To lCounter)
            lstLookup.Column = asMatches
    Me.reg1.Enabled = False
    Me.reg2.Enabled = False
    Me.reg3.Enabled = False
    'error block
    On Error GoTo 0
    Exit Sub
errHandler::
Sub Lookup()
    Dim vData
    Dim n                     As Long
    Dim lCount                As Long
    lstLookup.Clear
    With Sheet7
        Next n
    'error block
    On Error GoTo 0
    Exit Sub
errHandler::
Hi Debaser,
Some of the project numbers I have are 10056A 100765B & XBM16HJ7 (sorry for not including that in the sample file) so I'm not sure if your method would still work?
Thanks for the help so far!
You're welcome.
Just one last area that you might be able to help with.
So the search is super quick now!!
The only bit of slow down happens when double clicking the value from the ListBox that you wish to add to the Userform.
However it only takes a long time the further down the list you go.
So for instance if you want to add a project that is on row 10500 then it takes 10-15 seconds to add the data into the Userform.
Is there a miracle method like your search function that would work for adding the data to the userform?
Thank you again in advance!
The simplest way is either to store all the data in the listbox, or at least store the row numbers from the original search. I'll do the latter here.
Change the listbox to have a ColumnCount of 3 and set the column width of the last column to 0.
Then change your lookup code to:
Sub Lookup()
    Dim vData
    Dim n                     As Long
    Dim lCount                As Long
    lstLookup.Clear
    With Sheet7
        ReDim asMatches(1 To 3, 1 To lLastRow)
                asMatches(3, lCounter) = n
        Next n
            ReDim Preserve asMatches(1 To 3, 1 To lCounter)
    'error block
    On Error GoTo 0
    Exit Sub
errHandler::
Now the listbox code can just be:
Private Sub lstLookup_DblClick(ByVal Cancel As MSForms.ReturnBoolean)
'declare the variables
    Dim lRow                  As Long
    With Me.lstLookup
        ' get row number
        lRow = .List(.ListIndex, 2)
    'add the database values to the userform
    cNum = 4
    For X = 1 To cNum
        Me.Controls("reg" & X).Value = Sheet7.Cells(lRow, X).Value
as there's no need to search for the data.
Sub Lookup()
    Dim vData
    Dim n                     As Long
    Dim lCount                As Long
    lstLookup.Clear
    With Sheet7
        Next n
    'error block
    On Error GoTo 0
    Exit Sub
errHandler::
    Dim lRow                  As Long
    With Me.lstLookup
        ' get row number
    cNum = 4
    For X = 1 To cNum
    Exit Sub
You my friend are a life saver!!!
Thank you so much for this, the code is so much cleaner as well!
Funny when you work on something only to find it can be done 100x better, it is what I love about this site!!!
Thanks again Debaser! :)
