Separate Passport no and nationality
Juniad
Dear all.
plz help out to separate the pp no and nationality. Need result with formula for excel 2007
ZC1234562PAKISTAN
ZH1234563PAKISTAN
ZH1234564PAKISTAN
ZJ1234565PAKISTAN
ZL1234566PAKISTAN
ZP1234567PAKISTAN
ZT1234568PAKISTAN
ZU1234569PAKISTAN
ZX1234570PAKISTAN
05844445NIPAL
07BB12345COMOROS
0123456ALGERIA
A12345678EGYPT
A12345678NIGERYA
A2345678INDIA
AA1234567BANGLADESH
2123456LEBANON
shrivallabha
With your posted sample, assuming the split occurs at numerical-alphabetical point following formula works which assumes that your data starts from cell A1
=LEFT(A1,LOOKUP(2,1/ISNUMBER(MID(A1,ROW($A$1:INDEX(A:A,LEN(A1))),1)+0),ROW($A$1:INDEX(A:A,LEN(A1)))))
Once passport number is found then finding the country name is fairly straight forward.
=SUBSTITUTE(A1,B1,"")
Ideal option would be to have a lookup list of countries to check against. It will return fairly accurately but it wont be able to handle the spelling issues in the posted sample e.g. NIPAL should be NEPAL and NIGERYA shall be NIGERIA.
Somendra Misra
Just a different solution. I will make a table of countries, as it is fixed and does not change very often, as shown below.
67057
I will give this table a name such as CountryList.
Than I will use below formula to extract the country name first.
=INDEX(CountryList[Country],MAX(IF(ISNUMBER(SEARCH(CountryList,A1)),ROW(CountryList[Country])))-1)
(Note this is an Array formula and must be entered with Ctrl+SHift+Enter)
(I have assume your data starts from A1)
Than I will use below formula to extract Passport number
=LEFT(A1,SEARCH(C1,A1)-1)
Ignore, if you find this method troublesome.
