Same color between Bar Chart and Stacked Chart
Artic
I have a stacked bar chart where the each stack is created on sales per month for different departments.
There is another bar chart where each bar is sales in a month.
I want to show same color for months in both charts.
How can I do this?
Set one chart up as the base chart
get all your colors correct
Then select the second chart
Select each series in order, you can use the Up/Down arrow keys
Then Ctrl+1 to bring up the Format Series and color the series as appropriate to match the first chart
