Dr. Demento
p45cal came up with an awesome response to this question in 2015 (response #5).
However, I can't seem to get it to work; I thought it was working earlier but I believe had suppressed the error or hadn't noticed it. Below is the code I adapted from his.
At the line where With hdr.Resize(maxRow), I get RTE 424 - Object required. The TypeName(hdr) = String. I understand that Resize is a Range function, but I have no idea how to compensate for this error. I've tried assigning hdr as Range but that threw another error.
If anyone could give me some pointers, I'd be grateful! I'm not even sure what the Resize line does.
Thanks y'all.
Thanks y'all.
Sub run_sort_Columns_arr()
Dim sht As Worksheet
Set sht = ActiveSheet
Dim arr As Variant
arr = Array("SSN", "LASTNAME", "FIRSTNAME", " BIRTHDATE")
sort_Columns_arr sht, arr
Public Sub sort_Columns_arr(Optional ths As Worksheet, _
Optional rraOrder As Variant)
' ~~ Sorts columns using an array to direct order; _
however, will not order columns not listed in array _
***** twice as FAST as range version *****
' http://forum.chandoo.org/threads/re-arranging-columns-basis-hdr-names-vba-codes-using-array.24537/
Dim wbk As Workbook
Set wbk = ActiveWorkbook
If ths Is Nothing Then _
Set ths = wbk.ActiveworkSheet
Dim rngUsed As Range, _
rngHdr As Range, _
rngDest As Range, _
rng As Range, _
cell As Range
Set rngUsed = ths.UsedRange
Set rngHdr = rngUsed.Rows(1)
Dim cntr As Long, _
colArr As Long, _
rowArr As Long, _
cntrRow As Long, _
maxRow As Long, _
colArr_max As Long
maxRow = rngUsed.Rows.Count
colArr = 0
colArr_max = 0
Dim str_shtName As String
Dim arrResults As Variant, _
hdr As Variant, _
arrHdr As Variant, _
arr As Variant
ReDim arrHdr(1 To UBound(rraOrder))
' ~~ Remove all spaces in header terms & change all formatting to General
With ths
rngUsed.NumberFormat = "General"
For Each cell In rngHdr.Cells
cell.value = UCase(cell.value)
cell.value = str_trimAll(cell.value)
Next cell
For Each hdr In rraOrder
Set rng = rngHdr.find(What:=hdr, _
LookAt:=xlWhole, _
LookIn:=xlValues, _
MatchCase:=False, _
searchformat:=False)
' ~~ If rng is cannot be found in rngUsed, skip to next entry in rraOrder
If Not rng Is Nothing Then
colArr_max = colArr_max + 1
arrHdr(colArr_max) = rng ' adds the hdr cell to the array for later use
' Debug.Print "arrHdr(" & colArr_max & ") | " & arrHdr(colArr_max)
Next hdr
' ~~ To ReDim array to proper size, must only use header variables found in rngHdr
ReDim Preserve arrHdr(1 To colArr_max)
ReDim arrResults(1 To maxRow, 1 To colArr_max) ' ~~ ReDim the final size of the array
For Each hdr In arrHdr 'takes each of the hdr cells in turn
colArr = colArr + 1
With hdr.Resize(maxRow) 'expands the range
arr = .value 'puts the values into memory (arr)
.ClearContents 'clears that column's contents; the values are stored in memory.
For rowArr = 1 To maxRow ' ~~ importing each cell of the column into array
arrResults(rowArr, colArr) = arr(rowArr, 1) ' and put it into the final result array
Next rowArr
Next hdr
With ths
.Select
rngUsed.Cells(1, 1).Resize(maxRow, colArr) = arrResults ' ~~ Copy final array onto the destination sheet
' rngUsed.Range(Cells(, colArr_max + 1), Cells(, rngUsed.Columns.count)).EntireColumn.Delete ' ~~ Delete "extra" data outside specified array
