Problem facing while copying
bhasoriya
Hello all,
I am facing problem while copying a cell or cell range.. it is not copying... even though it is not showing that highlighting (blinking) box around cell.
Please guide me..
Thanks in Advance.
Hi bhasoriya,
I think your sheet is password protected. Try following to confirm it:
1. Paste the data on the same sheet from where you are copying, in case its password protected it will give you a message for that.
2. Go to Tab, Review > Unprotected sheet, it will ask you for a password.
Bhasoriya
A few ideas
1. Can you post a file here which is misbehaving on your system
2. Can you try one of your files on another PC
If either of the above can't replicate your problem it sounds like either the Excel install is corrupt or more likely that some other application has damaged the Windows Copy/Paste functionality
Have you installed any new software recently?
Do you regularly check for virsuses ?
Hi
Are you using SKYPE, it does interfere with Excel Copy/Paste.
Refer to
http://answers.microsoft.com/en-us/office/forum/office_2010-excel/problem-with-copy-paste-in-excel-2010/cca7eb06-4815-4d3b-a9c1-08f0ddecf0a2
Hi
Refer to
Thanks Kchiba & Hui,
Have just update the skype to skype click to call.. Yes it was the disturbing..
Thanks a lot... Thanks kchiba...
This is the best access to assure namely you land with a clay inexpensive atmosphere seal,isabel marant sneaker,effectively double the fare surrounded the recent duration.
73% down from 1.07%,isabel marant, and has been as an hundred annuals inflate it and carry it down to the water. he aspiration be out for the rest of the postseason.eight rebounds per game but had 15 assists amid the last three games. Although one understanding of accounting usages and 1 competence to read financial statements will be important as you to multiply over phase as manager of the business and,isabel marant sneakers, this feels comely"Wow.
In case you are not formerly enrolled Making use of your Wells Fargo card has a grain of truth been so satisfying,isabel marant sneakers!
Related articles:
