print data in userform list box
Chihiro
There is no direct method. Easiest way is to transfer contents of Listbox into temp sheet and print from there.
Shanzil
This is my user form, im looking for when i hit transfer button all data in listbox will transfer to worksheet so i can print this as you described above.
i really appreciate your help.
62155
Kenneth Hobson
If you want the full list, a scratch sheet can be printed with the list as Chihiro explained.
If we knew how the list was filled, there could be ways to print via a print area. If you want a screen snip of the userform, that can be done too.
Shanzil
This is th code im using for this userform.
Private Sub cmdCancel_Click()
Unload Me
Private Sub cmdtransfer_Click()
Dim i  As Long
For i = 0 To ListBox1.ListCount - 1
Cells(i + 1, 1) = ListBox1(i)
Private Sub ComboBox1_Change()
Dim database(1 To 100, 1 To 4)
Dim My_Range As Integer
Dim colum As Byte
Ark3.Range("A2").AutoFilter field:=1, Criteria1:=Me.ComboBox1.Value
For i = 2 To Ark3.Range("A100000").End(xlUp).Row
If Ark3.Cells(i, 1) = Me.ComboBox1 Then
My_Range = My_Range + 1
For colum = 1 To 4
database(My_Range, colum) = Ark3.Cells(i, colum)
Next colum
Me.ListBox1.List = database
ComboBox1 = ""
ListBox1 = ""
'Dim ctl As Control
'For Each ctl In UserForm1.Controls
'If TypeName(ctl) = "combobox1" Or TypeName(ctl) = "listbox1" Then
'ctl.Value = ""
'End If
'Next ctl
Private Sub UserForm_Click()
Belleke
Like this?
Change Sheetname with the real name of your sheet where the listbox records have to go.
Put the code under a button, make sure the name of the button and the buttonname in the code are the same.
With Sheets("sheetname")
    .Range("A" & .Rows.Count).End(xlUp).Offset(1).Resize(ListBox1.ListCount) = ListBox1.List
Shanzil
Hi Belleke,
This transfer only the first row value 4 not the rest of the contents. i want this whole contents to be transferred.
62156
Chihiro
Hence, my request to upload sample. It's so much easier for us to help you, without it we will be guessing at few things.
Like how your ListBox is populated in the first place.
As for @Belleke 's code not bringing in all columns. You need to add # of columns you need in .Resize portion of his code.
Ex:
    .Range("A" & .Rows.Count).End(xlUp).Offset(1).Resize(ListBox1.ListCount, 4) = ListBox1.List
Shanzil
I am tried but not getting, can you plz provide modified code. really appreciated
i tired different code :
dim ws As Worksheet
'Set ws = wb.Sheets("Ark1")
'Dim i As Long, rownum As Long
'rownum = 2
'For i = 0 To Me.ListBox1.ListCount - 1
'ws.Cells(rownum, 1).Value = Me.ListBox1.List(i)
'rownum = rownum + 1
'Next
End sub
same results :(
