Chihiro
If you need dynamic filtering using slicer or within report. Answer would be no. Since PQ is only evaluated at data load, and not during interaction with report. You'd need to use DAX for that (even with DAX, calculated table can't be used as that's evaluated once, right after initial data load).
If you need to set date range during data load. Just go to "Changed Type" step (i.e. before any other transformation is applied).
Then click on date column an apply your date range filter.
