Paste all at a click of all copied texts in clipboard then clear clipboard
Hello friends,
good day!
Is there any options to paste all the items at once which I have copied from various sources.
In the below example, I have copied 3 text items and clipboard history show in the bar, there is a button to "Paste All", but I am looking for a vba which paste all inside the cell like below;
before;
after paste;
Also once I clicked on paste then additional VBA would "Clear All" the clipboard history like below;
Thanks in advance.
Mehmud
I copied several things (text, ranges, charts) to the Office Clipboard. Then I turned on the Macro Recorder to see what is recorded while I manipulated items on the Office Clipboard.
When I pasted anything, it just recorded ActiveSheet.Paste. Same if I Pasted All. No indication of which clipboard item was pasted.
When I deleted anything from the clipboard, there was nothing recorded. Same with Clear All.
I then looked through the Object Browser and could find nothing that looked like it had anything to do with the Office Clipboard. We can safely say that the Office Clipboard is not exposed to VBA.
Hi Jon,
Thanks you so much for your valuable time.
Other ninjas and members, any suggestions for above task??
Thanks in advance!!
-Mehmud
Did You check?
Hi vletm,
Thanks for your reply!
The post you are highlighted was posted by me only.
And in that topic, I was unable to express my exact question also we was not come to final solution, hence I have created this post.
Request you all to please check this post and assist me.
Thanks and Regards,
Mehmud
