Needs Help with a Nested "FOR.. NEXT" Loop
carts
Hi everyone! I am trying to write a nested “FOR… NEXT” loop to create the following table in Excel
Any help is much appreciated! :)
Not VBA but a formula
A1: =IF(and(isodd(row(a1)),isodd(column(a1))),”Odd”, if(and(iseven(row(a1)),iseven(column(a1))),”Even”,””))
Copy across and down
Try this :
Public Sub FillOddsAndEvens()
           With Range("A1:T22")
                .Formula = "=IF(and(isodd(row(a1)),isodd(column(a1))),""Odd"", if(and(iseven(row(a1)),iseven(column(a1))),""Even"",""""))"
                .Value = .Value
Try this :
          Dim fillrange As Range
          Dim filltext As String
          Dim numcols As Long, numrows As Long, fillcolor As Long, i As Long, j As Long
          Set fillrange = Range("A1:T22")
          With fillrange
                numcols = .Columns.Count
                numrows = .Rows.Count
          For i = 1 To numrows
              If ((i Mod 2) = 0) Then
                  fillcolor = vbWhite
                  filltext = "Even"
                  fillcolor = vbYellow
                  filltext = "Odd"
              For j = 1 To numcols
                  With fillrange.Cells(i, j)
                        If ((j Mod 2) = (i Mod 2)) Then
                          .Value = filltext
                          .Interior.Color = fillcolor
                        fillcolor = IIf(fillcolor = vbWhite, vbYellow, vbWhite)
I was looking at Narayan's code and thought I could improve it slightly
So I used a For each construct with a range object as shown below
Public Sub FillOddsAndEvens2()
Dim fillcolor As Long
Dim c As Range
For Each c In fillrange
  If (c.Column Mod 2) = (c.Row Mod 2) Then
      filltext = "Even"
      If ((c.Row Mod 2) = 1) Or ((c.Column Mod 2) = 1) Then filltext = "Odd"
      fillcolor = vbWhite
      filltext = ""
  c.Interior.Color = fillcolor
  c.Value = filltext
It works fine
However when I timed it it is actually about 40% slower than Narayan's
Results below are the average of 10 runs
FillOddsAndEvens
Time = 0.1097656 seconds
FillOddsAndEvens2
Time = 0.2628906 seconds
I am working on another technique and will post about it later
Technique 3
This time I save time by only writing to the Worksheet once
Public Sub FillOddsAndEvens3()
Dim myArr(1 To 22, 1 To 20) As String
With fillrange
      fillcolor = vbWhite
      filltext = "Even"
      filltext = "Odd"
            myArr(i, j) = filltext
            '.Interior.Color = fillcolor
'Write all values to the worksheet
Range("A1:T22").Value = myArr
I have cheated and used Conditional Formatting for the Coloring
FillOddsAndEvens
Time = 0.1097656
FillOddsAndEvens2
Time = 0.2628906
FillOddsAndEvens3
Time = 0.06210937
About 40% faster than FillOddsAndEvens
