Need VBA code to select Range with Real values only
mandarp22
Hi All
I have data in “column D” in my work sheet, which is derived by formula and now I want to select a range of cells with VBA code in “column D” after the cell “D1” of the worksheet till the last row with the Real Value ignoring the cells with formula result “Blank” below the last Real value
Mandar
Attached file has 2 ways of doing it. First way used is the Named Range method for the dropdown list. Second way was VBA
  • sample file.xlsm
Hi Chirayu thanks for the help
I found this code below that works great for me. Only problem is I want to run this code on Sheet2 from commend button on Sheet1…..
Dim rng1 As Range
Dim rng2 As Range
Dim rng3 As Range
Set rng1 = Cells.Find("*", [a1], xlValues, , xlByRows, xlPrevious)
Set rng2 = Cells.Find("*", [a1], xlValues, , xlByColumns, xlPrevious)
Set rng3 = Range([d2], Cells(rng1.Row, rng2.Column))
Application.Goto rng3
Selection.Copy
could you please modify the code accordingly and help me. I am new to VBA
Mandar
