Need Some Help on Frequency Formula/countif every nth column
LaurenL
I have attached an example; I have a descriptive explanation on what/where I am stuck at in the document.
Thanks for any help~always appreciative!
Hi lauen
It's a bit difficult to understand your problem
Try:
E2: =IF(AND(B2<$K$1,D2<$K$1),1,0)
G2: =IF(F2<$K$1,1,0)
I2: =IF(H2<$K$1,1,0)
copy all down
If that isn't correct, can you explain what your trying to achieve?
It is not clear why cell I2 = 2 , while cell G3 = 0.
If I2 is 2 , it means we are looking at all the cells from B2 through H2 , excluding cells E2 and G2.
If G3 = 0 , it means we are looking at only cell F3 , and not counting the values in B3 and D3.
Hui,
I probably didn't explain myself well; I need to determine in the columns named "frequency" how often in the previous columns the cell is at or below 93.99 and it is a rolling count. However, as soon as it is at or above 93.99 then the counting stops and would start again if/when frequency was at or below 93.99. ( Looking for a pattern) entered your formulas in and reattached
Thank you for any help!
Narayan[/quot
Yes- that is correct: I need to determine a pattern every other column and report that pattern in the column: Frequency. Any suggestions?
Do you have any suggestions to help: I need to determine the frequency of 2 or more when cells B,D,F, etc are less than/= to 93.99 (continuous count). However, the moment those cells are above- the frequency stops counting and would only start again if/when the every other cell drops below the threshold of 93.99
How many more columns will this span ?
Will what ever solution is proposed need to be extended over several more columns , or will the columns E , G and I be the only ones ?
I need it to run for 26 columns in all (this is a performance tracker) built for every 2 weeks. The purpose of the formula I am seeking assistance is to be able to see pattern in performance.
Thank you for all your assistance.
Why do you have the frequency formula columns in between your data columns ?
If you can separate the data from the formulae , the formula can become that much simpler.
Secondly , why is the formula in column E referring to two columns of data which are in effect 4 weeks ? Isn't the column C also supposed to have a formula in it ?
Hi, Narayan
First thank you for your help...
R: The data represents performance indicators that are distributed biweekly; the goal is to keep a history of that data and after each period determine if they are meeting the goal or not. The Frequency column is to indicate how many in the previous consecutive period the standard was met or not.
R: I am open to any suggestions.
R: The formula in column E is the first set of data; there is no pattern established yet.
Thank you for all your help~
