Need help with trend arrow, current month to previous month
Kulraj Singh
This is the data I have I want to use up and down arrows to indicate trend from previous month to current month. Sample data is attached.
  • sample.xlsx
O3: =IFERROR(IF(OFFSET($A3,,COUNTIF($B$17:$N$17,">0"))>OFFSET($A3,,COUNTIF($B$17:$N$17,">0")-1),"↑","↓"),"")
Copy down
This uses the data in the Total row to determine the last Month with data and hence the previous month
Another option , which is available only if you have Excel 2010 or later versions , is to use Sparklines.
See the attached file.
  • sample.xlsx
