I am trying to obtain a Pass or Fail output in a single column based on two cells in two adjacent columns. This is numerical data. The data in each cell is a single value. Column A is the Pass/Fail output. Column B and C are values 1 and 2.
The value in column B must be within a certain tolerance limit. The value in column C must be within a certain tolerance limit. If either one (B or C) or both is not within tolerance, then the result is Fail. If both are within tolerance, then the result is Pass.
