need help to shorten my macro
Pilot5000
I have sheet (sheet3) with columns of data , each week the number of columns with data change but all the time start in the same column "E" , looking for help with macro that will take the data from column "E" and copy it to another sheet(sheet 1) at the 2 rows after the last row with data in column "A", and keeping loop until last columns wit data in sheet 3 . now I have macro that I work with but from doing some reading I understand 1) that this is not the best way to do that 2) my problems as you can see from my macro is that when it copy it take 2 columns at the time and copy them
Sub COPY_S1()
Range("E2:E" & Range("E" & Rows.Count).End(xlUp).Row).Select
Range(ActiveCell, ActiveCell.End(xlDown).Offset(0, 1)).Select
Selection.Copy Destination:=Worksheets("Sheet1").Range("A" & Rows.Count).End(xlUp).Offset(3)
Range("G2:G" & Range("G" & Rows.Count).End(xlUp).Row).Select
Range("I2:I" & Range("I" & Rows.Count).End(xlUp).Row).Select
Range("K2:K" & Range("K" & Rows.Count).End(xlUp).Row).Select
Range("M2:M" & Range("M" & Rows.Count).End(xlUp).Row).Select
Range("O2:O" & Range("O" & Rows.Count).End(xlUp).Row).Select
Range("S2:S" & Range("S" & Rows.Count).End(xlUp).Row).Select
Range("U2:U" & Range("U" & Rows.Count).End(xlUp).Row).Select
Range("W2:W" & Range("W" & Rows.Count).End(xlUp).Row).Select
Thank you or any help in advance
M.S
M.S
I think this will do it
Sub COPY_S1()
Dim i As Integer
For i = 5 To 23 Step 2
  If i <> 17 Then  Range(Cells(2, i), Cells(2, i).End(xlDown).Offset(, 1)).Copy Destination:=Worksheets("Sheet1").Range("A" & Rows.Count).End(xlUp).Offset(3)
Aplication.ScreenUpdating = True
Hi Hui
thank you for the effort and time to try and helping me
I tried your code and first time I run it I get message error "Next without For"
then I added "end if" , but I got another error message "Object required (Error 424)"
can you help me with that the code is not running
thanks again
There was a spelling mistake in the last Application
The code works fine with value in the data area
Where are you placing the code?
I have assumed it is in the Sheet2 code module
Sub COPY_S1()
Dim i As Integer
If it is elsewhere maybe add a single line to select the data sheet up front
Sub COPY_S1()
Dim i As Integer
Worksheets("Sheet2").Select
If you could paste the file it would make debugging so much easier
it's sheet3 and I will try the new instruction and let you know , I got this message on my phone and I am not in front of the my computer , I will do that later promise to let you know , that's the minimum I can do to thank you for everything you doing to help me
Sub COPY_S1()
Dim i As Integer
Sub COPY_S1()
Dim i As Integer
This is a slight bit shorter as well
Sub COPY_S1()
Dim i As Integer
  If i <> 17 Then Range(Cells(2, i), Cells(2, i + 1).End(xlDown)).Copy Destination:=Worksheets("Sheet1").Range("A" & Rows.Count).End(xlUp).Offset(3)
thank you very very much
Sub COPY_S1()
Dim i As Integer
