need help to boost speed of macro
ANKUSHRS1
I have written a macro in order to check booking and remaining stock status. i have over 4000 cases which i want to check another data containing +4000 cases as well.
the macro is too slow who take over 20 sec for every case. kindly gimme a idea so that i can boost this macro to save time.
Sub remaining_stock()
Dim i As Long, c As Long, i1 As Long, c1 As Long
Dim qly As String
Dim qly1 As String
Dim shd As String
Dim shd1 As String
Dim qty As Double
Dim qty1 As Double
Dim qtyR As Double
c = Sheets("WH STOCK").Cells(Sheets("WH STOCK").Rows.Count, "a").End(xlUp).Row
c1 = Sheets("Bookings").Cells(Sheets("Bookings").Rows.Count, "a").End(xlUp).Row
For i = 2 To c
For i1 = 2 To c1
Application.StatusBar = i & " Cases out of " & c & " Bookings " & i1 & " Cases out of " & c1
qly = Worksheets("WH STOCK").Range("a" & i).Value
qly1 = Worksheets("Bookings").Range("a" & i1).Value
shd = Worksheets("WH STOCK").Range("b" & i).Value
shd1 = Worksheets("Bookings").Range("b" & i1).Value
qty = Worksheets("WH STOCK").Range("c" & i).Value
qty1 = Worksheets("Bookings").Range("c" & i1).Value
qtyR = Worksheets("WH STOCK").Range("D" & i1).Value
If qly = qly1 And shd = shd1 Then
Worksheets("WH STOCK").Range("d" & i).Value = qty1
Worksheets("WH STOCK").Range("E" & i).Value = qty - Worksheets("WH STOCK").Range("D" & i).Value
If Worksheets("WH STOCK").Range("e" & i).Value < 0 Then
Worksheets("WH STOCK").Range("f" & i).Value = "Overbookings"
If Worksheets("WH STOCK").Range("e" & i).Value = 0 Then
Worksheets("WH STOCK").Range("f" & i).Value = "Stock Finished"
I just find a flow .....i can use [exit for] when condition match...but it is not much effective this data because matching cases very few....pls help
How about this solution which is nearly instantaneous and doesn't need VBA?
On the Bookings worksheet select the Data including headings,
Goto the Formula, Create From Selection Tab
Select Top Row, Apply
On WH Stock worksheet
D2: =SUMPRODUCT((MATERIAL_CODE=A2)*(SHADE=B2)*(Total))
E2: =IF(D2>0,C2-D2,C2)
F2: =IF(E2<0,"Overbookings",IF(E2=0,"Stock finished",""))
Copy all down
see attached file
  • ank____Conf-1.xlsm
Taking Hui's idea to VBA:
Sub Macro2c()
Set BookingsRng = Sheets("Bookings").Range("A1").CurrentRegion.Resize(, 3)
MCAddr = BookingsRng.Columns(1).Address(ReferenceStyle:=xlR1C1, external:=True)
ShdAddr = BookingsRng.Columns(2).Address(ReferenceStyle:=xlR1C1, external:=True)
TotAddr = BookingsRng.Columns(3).Address(ReferenceStyle:=xlR1C1, external:=True)
Set myrng = Sheets("WH STOCK").Range("A1").CurrentRegion.Columns(1)
Set myrng = myrng.Offset(1).Resize(myrng.Cells.Count - 1)
myrng.Offset(, 3).FormulaR1C1 = "=SUMIFS(" & TotAddr & "," & MCAddr & ",RC[-3]," & ShdAddr & ",RC[-2])"
myrng.Offset(, 4).FormulaR1C1 = "=IF(RC[-1]>0,RC[-2]-RC[-1],RC[-2])"
myrng.Offset(, 5).FormulaR1C1 = "=IF(RC[-1]<0,""Overbookings"",IF(RC[-1]=0,""Stock finished"",""""))"
myrng.Offset(, 3).Resize(, 3).Value = myrng.Offset(, 3).Resize(, 3).Value
Hui, I used SUMIFS instead of SUMPRODUCT since it's about 5 times a s fast.
