hi sir,
iam getting error in bolded and underlined please help on same
Sub copyPasteData()
Dim strSourceSheet As String
Dim strDestinationSheet As String
Dim lastRow As Long
strSourceSheet = "Sheet1"
Sheets(strSourceSheet).Visible = True
Sheets(strSourceSheet).Select
Range("k1").Select
Do While ActiveCell.Value <> ""
strDestinationSheet = ActiveCell.Value
ActiveCell.Offset(0, -2).Resize(1, ActiveCell.CurrentRegion.Columns.Count).Select
Selection.Copy
Sheets(strDestinationSheet).Visible = True
Sheets(strDestinationSheet).Select
lastRow = LastRowInOneColumn("A")Cells(lastRow + 1, 1).Select
Selection.PasteSpecial xlPasteValues
ActiveCell.Offset(0, 2).Select
Loop
