Hello Ninjas,
I need help modifying a formula that will populate general ledger codes from the "Adjustments Crosswalk" tab column B into the "Adjustments" tab column E. I would like a formula that populates the general ledger code from the Adjustment Crosswalk tab if it finds the matching reason code. If it doesn't find a general ledger code next to the reason code, then it should populate the general ledge code for the "Financial Class" ("Adjustment Crosswalk, columns A & B, rows 1 through 11). The correct results for some of the rows are illustrated in column F in the "Adjustments" tab. I appreciate your assistance.
Thank you, Gina
Thank you, Gina
