need help..index and match..
khyriel
1-Feb PUBLIC HOLIDAY
10-Feb SATURDAY
15-Feb SUNDAY
20-Feb SATURDAY
21-Feb SATURDAY
22-Feb SUNDAY
23-Feb SATURDAY
24-Feb SUNDAY
25-Feb 7:30 - 4:30 PM
26-Feb SUNDAY
27-Feb SATURDAY
From these data, i use this formula '=INDEX(A1:A11,MATCH("SATURDAY",B1:B11,0))
and the result shown as below,only returns the first data match.i want the date place side by side after the value match.thanks for any help.
Saturday: 10/02,
Sunday: 15/02,
Public Holiday: 01/02,
Khyriel
If you have
G12: Saturday
G13: Sunday
G14: PUBLIC HOLIDAY
then in
H12: =INDEX($A$1:$A$11,MATCH(G12,$B$1:$B$11,0))
Copy H12 Down
Try using this array formula
=IF(ISERROR(SMALL(IF($B$1:$B$20="SATURDAY",ROW($B$1:$B$20)),COLUMN(A$1))),"",
INDEX($A$1:$A$20,SMALL(IF($B$1:$B$20="SATURDAY",ROW($B$1:$B$20)),COLUMN(A$1))))
copy across as many as might be needed.
This is an array formula.
This means that you use Ctrl-Shift-Enter to commit the formula, not just Enter (array Enter it). Excel will put curly brackets around the formula in the formula bar, you don#t do this.
If you need to change the formula at any time, you must array Enter it again.
i've tried it both formula from Hui and xld, thanks alot.
the result only appears 1 result.
Saturday 10/2
Sunday 15/2
Public Holiday 01/2
can it show all dates in the same cell like example:
Saturday 10/2,20/2,21/2,23/2,27/2
Sunday 15/2,22/2,24/2,26/2
Public Holiday 01/2
thanks for all help
My example shows all results in adjacent cells if you drag the formula across. I would suggest that this is the best way to do it.
A B C D E F G H
1-Feb PUBLIC HOLIDAY SATURDAY 10/02 20/02 21/02 23/02 27/02
10-Feb SATURDAY SUNDAY 15/02 22/02 24/02 26/02 #NUM!
15-Feb SUNDAY PUBLIC HOLIDAY 01/02 #NUM!<--- Can sumone xplaine this?
20-Feb SATURDAY
21-Feb SATURDAY
22-Feb SUNDAY
23-Feb SATURDAY
24-Feb SUNDAY
26-Feb SUNDAY
27-Feb SATURDAY
i didnt know wheres the problem..this is the formula in the cell..
=IF(ISERROR(SMALL(IF(B1:B11=C3,ROW(B1:B11)),COLUMN(A1:A11))),"",INDEX(A1:A11,SMALL(IF(B1:B11=C3,ROW(B1:B11)),COLUMN(B1))))
