Need a Macro Code : Copying the values below the inserted blank rows
Hi awesome ninjas,
I have a macro code given below:
Sub Macro ()
'1:  Declare your variables.
    Dim MyRange As Range
    Dim iCounter As Long
'2:  Define the target Range.
    Set MyRange = Range("a28:ck1011")
'3:  Start reverse looping through the range.
    For iCounter = MyRange.Rows.Count To 5 Step -3
'4: Insert one blank row.
    MyRange.Rows(iCounter).EntireRow.Insert
'Step 5: Increment the counter down
    Next iCounter
My problem is to have code that would copy the values below the inserted blank row (Step 4) . Thanking in advance for the usual assistance.
vletm
delvillardennis
Your code tries to insert some rows ...
Which values would the code copy?
There is missing that information at all.
Upload a sample file which shows clear - before and after situations.
vletm
delvillardennis
I checked Your expected result from top and from bottom ...
I also checked that I wrote Upload a sample file which shows clear - before and after situations.
There were ... colors and so ... but where is that clear part which show Your needs?
delvillardennis
Hi vletm,
Please find below the explanation... thank you and kind regards.
62458
