Hello There,
I have a few NamedRange(s) defined in Sheet1 & Sheet2
When the user hits enter key on the last named range in Sheet1, the control should go to the first named range in Sheet2 (namedrange "FDescription"). But it doesn't
Below code:
This doesn't work:
This works:
I would like to know what is wrong in the first code as it does not navigate to worksheet "Sheet2"
Thanks & regards,
Don
Below code:
This doesn't work:
Worksheets("Sheet2").Range("FDescription").Select
This works:
Worksheets("Sheet2").Select
Thanks & regards,
Don
