Hey!
The only thing missing is:
pass to DATA sheet: Access123$
DATA sheet, in red. (J1:M5) must be removed. This data is the same as data under yellow cells, range (A20:D24), also in DATA sheet. The only difference is, that in red table this data is combined, so if under the yellow cells we have in one column "1" and in other "Insignificant", in red table this is combined to "1-Insignificant". In columns IMPACT and PROBABILITY the formulas are looking in the red table for the values. I dont want the formula to look in the red table (needs to be removed), but to look under the yellow cells, but the values in the OPEN sheet must be presented the same as now, so together "1-Indignificant" or "1-Unlikely", in the PROBABILITY column.
So red table in DATA sheet is now just helper column, but I want to delete it, and to formaula in IMPACT and PROBABILITY column in OPEN sheet must get the values from under the yellow cells in DATA sheet (A20:D24).
So basically I need this red table data and column Z with numbers removed (in data sheet), because, I will need that space for further calculations... But code must work like it did now
It must work on excel 2010.
Thanks.
