MAXIF Finding Max Value for Group in Column
johncharles1923
Hi - Thanks for helping. Trying to come up with a formula that will look at Column E groupings and give me the largest number in column G (for said grouping) in column H with an "X". I think it's a MAXIFS but can't quite finish the formula.
73863
Thanks for your help! And noted on the sample file. I tried the formula and it works! Just need the data to populate on the row with the largest value. Looks like it defaults to the first brand/group value from Column E.
73870
The formulas didn't just default to output the result against the first row of each block; they were carefully crafted to achieve that!
To bring the value forward on the same row
= IF( MAXIFS(Cases, Brand, Brand)=Cases, Cases, "")
Just a different way of working. I never use filters (or stripy tables come to that).
Their use tends to mess up the appearance and balance of the worksheet and I prefer having both the original and filtered tables visible.
73886
73888
An alternative solution is with Get and Transform
let
    #"Changed Type" = Table.TransformColumnTypes(Source,{{"Year", Int64.Type}, {"Brand", type text}, {"UOM", type text}, {"Cases", type number}}),
    #"Grouped Rows" = Table.Group(#"Changed Type", {"Brand"}, {{"Max", each List.Max([Cases]), type nullable number}})
in
    #"Grouped Rows"
