Thomas Kuriakose
Respected Sirs,
There are two worksheets in the attached workbook, one is "Entry" and the other is "Final".
There is input data in worksheet "Entry" from range C86 to D161 and this range can vary based on selection in the other data fields marked in grey and has not been shown. There are two columns of data with header "Number" (C85) and "Month"(D85). The rows below have data for number and the text assigned to each number.
The Final worksheet has the header with "Number"(A1) and "Months"(B1:M1) in columns.
The requirement is to lookup the "Number" and "Month" from "Entry" worksheet and match the row in which "Number is present in the "Final" worksheet and then match the column header which has the month and copy the text from "Entry" worksheet" to this cell. This has to be repeated for all the numbers in the Entry worksheet which has a matching "Number" in the "Final" worksheet
We do not want a formula based solution as the texts will vary month on month and the number will also not be the same every month and this will replace the data in the "Final" worksheet.
I found the below code but is keeps running and after a while stops without giving any results.
Thank you very much for your guidance and support always,
with regards,
thomas
Sub CopyData()
Dim iRowHeader As Integer, iColHeader As Integer
Dim rngSrc As Range, rngDest As Range, celSrc As Range, celDest As Range
iRowHeader = 2
iColHeader = 1
Set rngSrc = .Worksheets("Entry").Range("$D$86:$D$1000")
Set rngDest = .Worksheets("Final").Range("$B$2:$M$1248")
For Each celDest In rngDest
For Each celSrc In rngSrc
If .Worksheets("Entry").Cells(celSrc.Row, iColHeader).Value = .Worksheets("Final").Cells(celDest.Row, iColHeader).Value And _
.Worksheets("Entry").Cells(iRowHeader, celSrc.Column).Value = .Worksheets("Final").Cells(iRowHeader, celDest.Column).Value Then
celDest.Value = celSrc.Value
Next celSrc
Next celDest
with regards,
thomas
