Macro/VBA for grouping/outline of WBS structure
Status
Not open for further replies.
ok, what i found was, you only have to change into:
Private Declare PtrSafe Function IsClipboardFormatAvailable Lib "user32" (ByVal wFormat As Integer) As Long
- if anyone of you is using the 64 bit Office version. Please note that, to use the Stoplight WBS Tree, the pictures you use should be in the same directory nas the workbook is, because in any other directory it will not update.
sheet "WBS PIC" does not work.check that too.
I am sorry, i am using Office 32 bit on my own and have no clue what to change inside the codelines to make it executable in Office 64 bit.
Ah. Okay, tried to do a bit more testing. This seems to be an improvement, at least.
Sub BuildOutline()
Dim lastRow As Long
Dim grpRow(1 To 8) As Long
Dim i As Long, j As Long
Dim curLVL As Long
With ActiveSheet
    .Cells.EntireRow.ClearOutline
    lastRow = .Cells(.Rows.Count, "A").End(xlUp).Row
    'Setup initial values
   For i = 1 To 8
        grpRow(i) = lastRow
    For i = lastRow - 1 To 2 Step -1
        curLVL = lvlCount(.Cells(i, 1).Value)
        If curLVL > lvlCount(.Cells(i + 1, 1).Value) Then
            grpRow(curLVL) = i
        ElseIf curLVL < lvlCount(.Cells(i + 1, 1).Value) Then
            .Range(i + 1 & ":" & grpRow(curLVL + 1)).EntireRow.Group
            'If we go up a level, all previous lower levels reset
            For j = curLVL + 1 To 8
                grpRow(j) = i - 1
            Next j
Function lvlCount(WBS As String) As Integer
lvlCount = Len(WBS) - Len(Replace(WBS, ".", "")) + 1
End Function
Hi Dear
I used of your macro for grouping my Project WBS but unfortunately I have error in macro or I have Debug. I give snapshot of my PC screen for clarified this problem. please find attached file for your Macro Snapshot.
Best Regards,
Hi, Sorry to bring this again. Can someone point where i can find the link/ step by step instruction to run the Better Outliner.xlsm to achieve the formatting and outlining
To install a macro:
1. Right-click on a sheet tab, and select 'View Code'
2. In the Visual Basic Explorer (VBE) that opens, go to Insert - Module
3. Paste the given code into the white space that appears
4. Close the VBE
5. In your workbook, open the macro menu (Alt+F8)
6. Select desired macro and hit 'Run'
Beautiful!!! I cannot thank you enough, there is no way I could have come up with any of that and this has been driving me crazy... so THANK YOU!!
Ah, I see now. Goofy little thing about XL...originally accountant type people designed it, and their totals are at the bottom, so the outline rolls down. In Data ribbon, in bottom of Outline group, you can hit the little button, and remove that checkmark:
However, since we may use this on other workbooks, I added a line into the code to have the macro make this switch. :cool:
Hi, I did used it earlier, but now i dont get to see how i can use on the excel output of project file. Can i request your support to explain - step by step on how to use this better outliner.xlsm file and acheive the required formating.
To install a macro:
4. Close the VBE
Thanks for that Luke, Yes In fact, there were 2 modules which I had copied and even saved the file as macro enabled, but still the formatting is not happening. not sure why it is so. What can I do next, thanks for your support in advance.
hi i have a question if in a wbs in last row you rught 1.4 or 1.5 it can not assign true group level ..why ?
mojtaba
This thread has opened few years ago.
You should open a new thread.
Please reread Forum Rules
There are more hints - how You should continue.
I also indent my cells based off of WBS numbers but I use a count of the periods. I create a separate column which counts the number of periods within each WBS element for each row. The number of periods indicates the level of the WBS element. I then run a small macro which indents the cells based off of the period count.
The issue with grouping is it difficult to determine how to group within a group based off of the WBS structure, considering there could be several rows which need grouped within another group. If I could somehow capture the first and last cells of the first highest WBS element and then make my way inward.... dickssportinggoods feedback www.lowes.com survey
Status
