Macro to specify zoom level for the workbook
Hi listers,
I want to include a box (or a cell) in my front sheet so the user can specify the zoom level for the entire workbook. I have come across the following macro which lets you zoom to a specified percentage but not exactly what I am looking for.
Sub SetZoom()Dim ws As Worksheet
ForEach ws In Worksheets
ws.Select
ActiveWindow.Zoom =85 //change as per your requirements
Next wsEndSub
I would appreciate your help.
Thank you!
ExcelStuff
Thanks, Deepak. This is excellent and works perfect on your workbook!
Can I ask a silly question: how do I import this to my workbook? I am more familiar with writing or copy/pasting sub routines directly into my file but this one doesn't seem to work in this way. Also would I need to run this one? Sorry this is ridiculously basic question but I would appreciate your help.
Also, is it possible to limit the range that they could put in the cell (say between 70 and 100)?
Thanks again
ExcelStuff
Not an issue!!
Copy to Sheet~Right Click on sheet name>View Code then copy paste the below code there.
Dim ws As Worksheet, w As Worksheet
Set w = ActiveSheet
    If Target.Address = "$A$1" Then
        For Each ws In Worksheets
            ws.Select
            ActiveWindow.Zoom = Sheet1.[A1].Value '//change as per your requirements
        Next ws
w.Activate
if u wish to manually run the code then copy paste the below code in a module
Sub SetZoom()
Set w = ActiveSheet
            ws.Select
        Next ws
w.Activate
To limit add this to up of Application.ScreenUpdating = False
If Sheet1.[A1] < 70 Or Sheet1.[A1] > 100 Then Exit Sub
