I need to code an macro, where E column should highlight when its mismatches with the list of OMSIDS count ( column F) according to ticket ids(column B)
Example:
In ticket number: 2800876 , we could see in F column lists of OMSIDs are totally 3 but in OMSID count column, they have mentioned as 4 instead of 3 , which is wrong
Another ex: 2796053 , here totals OMSIDs are 10 but in OMSID count they mentioned as 9 which is wrong
So I need an macro where comparing the ticket id ( column B) along with lists of OMSID(coulmn F) , OMSID count (column E) should be highlight if there is mismatch in count
Likewise I have datas around 15,0000+ and been checking this manually till date,
kindly help, I have attached the sample sheet too
Example:
