dolphintabby
Hello, I have been using Excel for quite sometime but am new to the VBA side of it. I am trying to create a Macro using VBA and The 1st Macro I created using just record works fine. When I tried to create a 2nd Macro in the same worksheet but using VBA instead of record and I assign it a shortcut key the shortcut key for the 2nd Macro won't work and for some odd reason the name keeps auto populating with the workbook name.the name I selected for the Macro-for example 'MyNameTest.xls'!'.ColorMeRed and the short cut key should be Ctrl+Shift+J when I press those keys it gives me a ping sound and does nothing. If I go to the developer tab and press Macro and select run it works fine. If anyone could please help I would greatly appreciate it.
