MACRO HELP
Hi Friends,
I have this data in excel sheet and i want to run macro on it.
What i want to do is whenever i put name in column A, rest details should run automatically with the help of the formula.
But, now the thing is my boss needs only in macro even after giving him the sheet with formulas which automatically captures require details in other columns once you enter in Column A. but, still he needs a macro to be run on it.
Attached is the dummy data.
Can you guys please help me how to put macro for such case, if i input name in column A rest details should come automatically, also i have put formulas for your understanding i.e what i am trying to capture , which is highlighted in blue color.
Thanks in advance for your help.
Gaurang.
Hui,
Lol...
But, the problem is i cant edit or add if the sheet is protected since there will be entries on daily basis. is macro possible.?
i dont see any difference between the formula i used and macro both will give same result after all but still my boss wants macro...lol
Anyways thanks for your reply hui!
Gaurang.
Hey somendra,
Just a small doubt, you have used
"For i = 2 To lastrow"
what is this i for??
Can you explain coding, if possible.
Thanks!
Gaurang
@Gaurang Mhatre
Lastrow is a variable which will store the last row with data in column A of this sheet.
Now i is a loop variable which goes from row 2 to last row in this case 6 because your formulas has to apply on this data. If you insert more name , mobile # and amount and press run button it will execute for all rows.
Rest codes are simple formula which were there in your sheet.
To use Formulas
You unprotect Column A
Protect Columns B:Z (Where the formulas are)
Add enough formulas to Row 1000 etc
Protect the Worksheet and Hide Formulas
Voila
A person can add records in Column A and results will go to columns B:Z
But no visibility of formulas
You can even password protect it
@ashish mehra
You mean to say in sample file the names are like last name,first name and still you want to extract last name as earlier?
One more questions--- are all names listed in this pattern or some in this and some in like the last one?
Dear SM,
Column Name will contain name as "Gaurang Mhatre" and "Mhatre, Gaurang".
Output required: "Mhatre" in all scenarios.
AM:)
Why not have this macro work automatically whenever there is change in column A?..
Your boss doesn't have to click button also...:)
like...
If Target.Column = 1 Then
Dim ws As Worksheet
Set ws = Worksheets("Sheet1")
lastrow = ws.Range("A" & Rows.Count).End(xlUp).Row
Cells(i, 4) = Rnd()
Cells(i, 5) = Mid(Cells(i, 1).Value, InStr(Cells(i, 1), " "), Len(Cells(i, 1)) - InStr(Cells(i, 1), " ") + 1)
Cells(i, 6) = Left(Cells(i, 2).Value, 5)
Cells(i, 7) = Left(Cells(i, 4).Value * 1000000, 4)
Cells(i, 8) = Cells(i, 5) & Cells(i, 6) & Cells(i, 7)
With Regards
Rudra
Hi, Gaurang Mhatre!
You have many options in the menu, just choose that which you think it might suit better for your job:
a) Somendra Misra's: for a lot of rows it'd be slower than c), despite it should be run again if any value in columns A:B changes as it stores fixed values (even that of RAND).
b) rumshar's: solves partially the update problem (it should includes column B too), but it runs a bunch of times on the same cells had they been changed or not, i.e., doesn't circumscribe to Target range and operates on all column A.
c) Somendra Misra's with formulas: much faster for any number of rows as it avoids the loop cell by cell, solves update solution but not additions.
Sub populate_values()
Dim ws As Worksheet
LASTROW = ws.Range("A" & Rows.Count).End(xlUp).Row
Cells(2, 4).Formula = "=RAND()"
Cells(2, 5).Formula = "=MID(A2,SEARCH("" "",A2),LEN(A2)-SEARCH("" "",A2)+1)"
Cells(2, 6).Formula = "=LEFT(B2,5)"
Cells(2, 7).Formula = "=LEFT(D2*1000000,4)"
Cells(2, 8).Formula = "=E2&F2&G2"
Range("D2:H2").Copy
Range("D2:H" & LASTROW).PasteSpecial xlPasteFormulas
d) Convert your range into structured table and forget about formulas: just set them in 1st data row (2)... et voilà.
Regards!
