Macro help for excel
IKHAN
Need Help to creating macros
I have to COPY/paste items in column A of sheet 1 (primary sheet) recieved daily
Trying to acheive the following using macros
-To check and Delete column A(PASTED ITEMS) SHEET 1 (anything after "-" example - "Apple-bad" to show as "Apple")
-To check and delete duplicates from column A sheet 1 of pasted items(example:If item Apple exist in both Column A: Row1 and ColumnA : Row6 TO DELETE 1
item)
-To check in sheet 2 and if any match in column A of (sheet 2),Put it as "MATCHED" in column C of sheet 1
- When items copied/pasted in column A of sheet 1 ,To check/compare in sheet 3 predefined items in column F ,column J and COLUMN S and copy matched items in
Column E, column F and Column G respectively in SHEET 1
-Next delete complete row from column G from sheet 1 which says "EOL"
-Highlight SHEET 1 and Sort column F of sheet 1 in ascending(A-Z)
-Highlight sheet to ARIAL 11
Finally to compare data from sheet 4 column A when data is pasted in sheet 1 column and One pop up message appears " Apples and applesB matched and Orange
and orangeB matched" if any match found.
1. Here's the find & replace code:
[pre]
Sub RemoveDash()
Columns("A:A").Replace What:="-*", Replacement:="", LookAt:=xlPart, _
SearchOrder:=xlByRows, MatchCase:=False, SearchFormat:=False, _
ReplaceFormat:=False
2. Remove duplicates
[pre][code]Sub RemoveDuplicates()
Dim LastRow As Integer
With Worksheets("Sheet1")
LastRow = .Range("A65536").End(xlUp).Row
For i = LastRow To 1 Step -1
If WorksheetFunction.CountIf(.Range(.Cells(LastRow, "A"), .Cells(i, "A")), .Cells(i, "A").Value) > 1 Then
.Cells(i, "A").EntireRow.Delete
3. This is a simple formula of:
=IF(COUNTIF(Sheet1!A:A,A2),"MATCHED","NOT MATCHED")
4. I'm not sure what you're asking. =(
5. Macro
Sub DeleteEOL()
LastRow = .Range("G65536").End(xlUp).Row
If .Cells(i, "G").Value = "EOL" Then
.Cells(i, "G").EntireRow.Delete
[/pre]
6. Sort col f
Sub SoftColF()
Columns("F:F").Select
ActiveWorkbook.Worksheets("Sheet1").Sort.SortFields.Clear
ActiveWorkbook.Worksheets("Sheet1").Sort.SortFields.Add Key:=Range("F1"), _
SortOn:=xlSortOnValues, Order:=xlAscending, DataOption:=xlSortNormal
With ActiveWorkbook.Worksheets("Sheet1").Sort
.SetRange Selection
.Header = xlNo
.MatchCase = False
.Orientation = xlTopToBottom
.SortMethod = xlPinYin
.Apply
End Sub[/code][/pre]
7. Not sure what "highlight to arial 11" means.
There's a lot of confusion in your post...perhaps uploading a workbook would be helpful?
Luke - Have uploaded the file for your ref. and also inserted comments on whts not working. ..Thanks for your help
Issue 1 - To be Deleted Complete ROW if Column "G" has "End of Life" in sheet 1 - Not working when MACRO used
Issue 2 -looking for Macro to compare daily copied data in Column A in sheet 1 with Critical(sheet2) Column A, If match found write in Column C of Sheet 1 as "Matched"
Issue 3 - (Using Formula currently -Need MACRO)(When I copy/ paste daily data into Column A of sheet 1,It looks for corresponding data in pre Inputted sheet column F, J,S and it pastes in Sheet 1 Column E,F,G)
Issue4 - Select all Sheet 1 from Row 5 to column G and sort by Column F in ascending order(A-Z)
Issue5-Select ALL sheet 1 from Row 5 to column G and change FONTS to ARIAL and size 11
Download link:
https://hotfile.com/dl/153541673/6c15908/TEST_FILE.xlsx.html
Forum link:
HTML link:
Delete link:
https://hotfile.com/kill/153541673/0b412b4e07d6fa0bbf7c5580f6bb478c1eea016f.html
If there is a problem displaying the e-mail or you just can't copy the adresses click on or copy & paste this URL into your browser's address bar to see all the links:
http://hotfile.com/links/153541673/72a8379/TEST_FILE.xlsx
Have uploaded file for your ref. ,
Issue 1- To be Deleted Complete ROW if Column "G" has "End of Life" in sheet 1 - Not working when MACRO used
Issue2- looking for Macro to compare daily copied data in Column A in sheet 1 with Critical(sheet2) Column A, If match found write in Column C of Sheet 1 as "Matched"
Issue 3- (Using Formula currently -Need MACRO)(When I copy/ paste daily data into Column A of sheet 1,It looks for corresponding data in pre Inputted sheet column F, J,S and it pastes in Sheet 1 Column E,F,G)
Issue-4- Select all Sheet 1 from Row 5 to column G and sort by Column F in ascending order(A-Z)
Issue-5- Select ALL sheet 1 from Row 5 to column G and change FONTS to ARIAL and size 11
