Macro - Delete blank cells - problem
Dhamo
Hi
I need to delete all rows if if the cell in U column is blank.
Sub a()
Worksheets("Testing Execution Data").Select
For i = 15 To 100
If Cells(i, 21).Value = "" Then
Cells(i, 21).Select
Rows(ActiveCell.Row).Select
Selection.Delete Shift:=xlUp
But it is missing few rows. I think the problem is with my loop. Can anybody point out where I should correct?
Note: I have formula in U column. (=if(a1="","","Valid")
Hi Dhamo..
I have not tested the code.. but.. try to change
For i = 15 To 100 to
For i = 100 To 15 step -1
as when you start delete row 15, row 16 will take place of 15, and for loop will exclude row 16, as it was currently row 15, what you have already checked..
Confused... ;).. sorry.. but that's the actual problem.
Deb
Thanks Deb. It works.! But my actual row range is 15 to 1652. It takes more than 3 mins to delete the rows. Is there any possibility to reduce the time?
Also I tried with this code.
Dim myColm As Range
Set myColm = Range("C:C")
myColm.SpecialCells(xlCellTypeBlanks).EntireRow.Delete
As I already mentioned in my first post, i am using formulas and it is not deleting the rows which has formulas.
Dhamo
Try: Set myColm = Range("C1", Range("C1048576").End(xlUp))
That will reduce the calcs to the cells in Column C between C1 and the bottom of the data
Hi !   Time is long 'cause of these awful Select !
Your code should be without any Select :
If Cells(i, 21).Value = "" Then Rows(i).Delete
Use at the beginning also  Application.ScreenUpdating = False
 your code will be faster …
Think, but think object ‼
