Loop through controls on UserForm using For Each Next Loop
Is there a way in Excel VBA to loop through and check if all controls (text boxes) on a userform are empty or not ?? I have 11 text boxes on a userform with names like: Arec1, Arec2, Arec3... Arec11. A msgbox should pop up and let the user know which text box he/she has left out and needs to be filled in before proceeding onto the next userform. Should this code be placed in the click event of a button on the same form ??
Appreciate any good answers.
~~ Maneesh
With as short as possible..
I have added few lines in .. UpdatePID
and each textbox change event.. calling that routine..
Dim j As Integer
    For j = 6 To 11
        If Trim(Me("Arec" & j).Text) = "" Then Exit For
    Me("cmdnext").Visible = j = 12
cmdNext.. will not visible untill you filled all text boxes..
Thanks Devraj for this!
I want to know what the last line mean ?? Why is there 2 equal (=) signs in the same line ???
Me("cmdNext").Visible = j =12
I usually set all the controls default values in the Userform_Initialize event
  Textbox1.Value = 10
  'Etc
  Textbox1.Value = 10
  'Etc
Hi Hui,
Please explain the meaning of the above line of code:
Textbox1.Text = 10
'Etc
Same thing I ask here. What does the equal sign (=) after Textbox1.Text do ??? Can you please elaborate ??
Thanks and A VERY HAPPY NEW YEAR TO ALL MEMBERS & USERS OF THIS EXCELLENT FORUM !!!!!!!!!!!!!!!
Maneesh
Maneesh
UserForm_Initialize() is the routine that runs when the User Form first opens
Putting code in here ensures it is run before any user interaction on the user form
Textbox1.Text = 10 will place the value 10 in the text box called TextBox1
You will have to do the same for your list/combo boxes etc that are on your userform
