YasserKhalil
Hello everyone
I have devised a code using IE to login chandoo
It is working well ..
I need a way to login the website using xml with credentials ... something like that
Sub Login_Chandoo_Forum_Using_Internet_Explorer()
Dim ie As Object
Dim e As Object
Set ie = CreateObject("InternetExplorer.Application")
With ie
.Visible = True
.navigate "https://chandoo.org/forum/login/"
Previous:
Application.Wait Now() + TimeValue("00:00:03")
On Error GoTo Previous
.document.getElementById("ctrl_pageLogin_login").Value = "myemail@gmail.com"
.document.getElementById("ctrl_pageLogin_password").Value = "mypassword"
For Each e In .document.getElementsByTagName("input")
If e.Value Like "Log in" And e.Type = "submit" Then
e.Click: Exit For
Next e
Sub httpclient()
Dim xmlhttp As New MSXML2.xmlhttp, myurl As String
myurl = "https://chandoo.org/forum/login/"
xmlhttp.Open "POST", myurl, False
xmlhttp.setRequestHeader "Content-Type", "application/x-www-form-urlencoded"
xmlhttp.send "credtentials here"
MsgBox (xmlhttp.responseText)
