Issue with dates format
Status
Not open for further replies.
abhi_jain80
Hi folks,
I got the support on vba script from another excel forum in which the code is pulling out the data in new worksheet from two worksheets for the unique transactions on click of the button. Here is the link...https://www.excelforum.com/excel-programming-vba-macros/1349511-new-worksheet-based-on-multiple-worksheets.html#post5523218
It is absolutely working fine except the date format issue...All the dates appeared in the "output" sheet are not in date format, some are in text format while in the "transactions" sheet from where the dates are being pulled are in date format. See the sample file attached (issue highlighted in yellow color). I observed that this issue appears only where there is only 1 transaction.
I spent loads of time on the issue but could not be able to figure out the workaround. Hope I am clear with the requirement. Just wondering if anybody came up with the same issue or aware of any solution. Many thanks in advance...
Abhi
Marc L
Hi,​
so the code is not good for your need and it's weird to ask on another forum than the one where you grabbed it …​
Use the Range.Copy method in order to keep the data type as it is in the source sheet.​
abhi_jain80
Hi Marc,
The code is good for my need, the only thing...it is not giving the dates in the right format. I am newbie to vba, would be of great help if you could modify the code with Range.Copy method, as you are suggesting.
You will see the thread is closed in another forum and there is no solution available for this issue, hence thought of reaching out to another forum for expert comments. I hope this helps...Thanks
Marc L
This thread is closed as I solved it in the original forum - classic beginner trap when a range property is missing - for a reminder to the code author …​
Status
