Index small if row (match if begins with....
vasim
In the formula
=Index(range1,small(if(range2=cell,row(range2)),row())
when dragged gives me the first cell match, second cell match & so on.... is it possible to get match that begins with or contains...something like
=Index(range1,small(if(range2=cell&"*",row(range2)),row())
=Index(range1,small(if(range2="*"&cell&"*",row(range2)),row())
Both the above doesnt work...any help
Thanks Faseeh....From the two questions, for the second this is exactly what I was looking for...
This can be used for "contains".....any idea how can we incorporate for "begins with" .....
THANKS AGAIN...
Thanks Faseeh, the list entries present 1)AA-BBC & 2)BBC-AA for the lookup value as AA, however I was looking to get only AA-BBC & not BBC-AA as AA-BBC starts with AA (then the second match that starts with AA), whereas BBC-AA starts with BB and not the lookup value (AA).....
(EDIT Added - to entries to avoid confusion...)
Hi Vasim...
See if this formula solve your purpose...
=IFERROR(INDEX($A$1:$A$6,AGGREGATE(15,6,IF(SEARCH($C$1&"*",$A$1:$A$6)=1,ROW($A$1:$A$6)),ROWS($A$1:A1))),"")
Enter the Ctrl+Shift+Enter.
I had attached the file also. It will give all the data starting with the criteria set in Blue Cell.
Somendra.
