Index & Match on greater than
Ang Ang
Hi Excel,
Not sure what I am doing incorrect. My index and match won't work on greater than. It works on exact or less than. Attached is the file.
Thanks,
  • Index & Match (greater).xlsx
This is a common error using the Match function
If you read the Help for Match
You will see why it is not working
You maybe able to rearrange your data by sorting on Column B if that is what you require
Since your data is in ascending order , the third parameter of the MATCH function , which has been put to -1 , should be 1 (+1).
It is an arrangement issue. For -1 the values need to be in descending order. Yours are in ascending order.
Thank you all,
Got it. So is there a formula to look up the next highest value without rearrange my data?
