Index, Match, Max
GB
Hi
I am trying to write an index match max formula, to return the maximum "Sales" value where "Week" = 1 and "Day" = Tue. There may be a more efficient formula so I am open to any suggestion. I have attached the simple spreadsheet and all the data has named ranges.
http://dl.dropbox.com/u/60464004/Excel/IndexMatchMax.xlsx
Birko
Birko
Give this a try:
=MAX(IF(Week=1,IF(Day="Tues",Sales,),))
Ctrl Shift Enter
ps: Good use of Named Formulas it makes the formula so readable
You may want to consider the following changes to the Named Formula
Week: =OFFSET(Sheet1!$A$6,,,COUNTA(Sheet1!$A:$A)-1)
Day: =OFFSET(Week,,1)
Sales: =OFFSET(Week,,2)
Doing the above allows you to add or delete data and the Named Formulas will adjust accordingly
Hi Hui,
thanks for your very quick response although it didn't work for me??? I evaluated the formula and the "Week" component returned a "#VALUE". Any suggestion to rectify?
thanks
Birko
Whooops
Also forgot to mention it is an array formula so enter it with Ctrl Shift Enter
